Re: Front Sway Bar for Drag Racing
[Re: SRT8Challenger]
#176343
12/27/08 05:25 PM
12/27/08 05:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The weight and supposedly,the front end works better.
However,on a 12.20 sec B-body we raced,removing the sway bar didn't do a thing.
#176344
12/27/08 05:28 PM
12/27/08 05:28 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The way an anti-sway bar works is by keeping the front suspension preloaded when weight transfer tries to unload it. It's designed to help stop side to side unload, but it also does a good job of stopping front to back unload. In a drag car, the first thing you want when the light goes green is immediate unload of the front suspension, transferring all possible suspension load to the rear. In a drag application, this piece of hardware works against you.
shedding the 8-10 lbs is also a step in the right direction.
[Re: joshking440]
#176346
12/27/08 05:51 PM
12/27/08 05:51 PM
Posts: 5,898 Florida
Locomotion
To the scrap yard it goes then
Shame on you! If you're going to scrap it, send it to me. I'll sell it and buy some performance enhancing part with the money. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: StealthWedge67]
#176347
12/27/08 06:57 PM
12/27/08 06:57 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
After you take it off,check your pinion angle ![](/ubbthreads/images/graemlins/penguin-015.gif)
[Re: B G Racing]
#176348
12/27/08 07:44 PM
12/27/08 07:44 PM
Posts: 6,295 U.S.
moparniac
U.S.
I sold mine. it weighed 20lbs....
Mopar Performance
[Re: ZIPPY]
#176350
12/28/08 09:50 AM
12/28/08 09:50 AM
Locomotion
Well, actually it WILL make a difference. But with so many variables involved and the small amount of weight (i.e.: 20lbs = .02), it's usually not noticable. Air temp, wind, humidity, water temps, shift points, etc. from run to run can easily do that much. But it's a bunch of those "little things" that eventually add up to obvious gains. Removing weight means less mass to move and removing the sway bar does loosen up the front suspension. If a car normally works well with it, removing it can provide that extra bit of weight transfer to help if traction conditions may be a little less than optimum for your combo. ![](/ubbthreads/images/graemlins/Twocents.gif) ...and as mentioned earlier, you can always sell it to someone who can use it and put the money towards something that will help even more than "just" removing the sway bar!
