2014 Ram TPMS Light:
#1762463
02/25/15 02:42 AM
02/25/15 02:42 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Ft. Left tire was indicating a little low, so the TPMS warning light came on. I took it in for an oil change at my regular Dodge dealer & looks like the guy inflated all 4 to 36-37 pounds according to the IP display. The warning light is still on. Is there a way to "reset" this light, or did the guy over-inflate the tires? (I told him to put each at 35 pounds)
Re: 2014 Ram TPMS Light:
[Re: Sunroofcuda]
#1762464
02/25/15 03:42 AM
02/25/15 03:42 AM
Posts: 156 San Diego
Instigate
San Diego
The sensor is going to be expecting to see the PSI amount labeled on your driver side door panel.
[Re: Instigate]
#1762465
02/25/15 06:04 AM
02/25/15 06:04 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
How far have you driven it since the tire was aired up? I think you need to drive the vehicle for a few miles before the light will reset. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
[Re: MOBodyman]
#1762467
02/25/15 06:50 AM
02/25/15 06:50 AM
Instigate
San Diego
This is also true.
[Re: Sunroofcuda]
#1762469
02/25/15 03:06 PM
02/25/15 03:06 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The only people that need the TPMS light are the disconnected people that should not be behind the wheel for any reason Those are the fools that are texting and driving. My wife's Honda TPMS system light is glowing and has been for months...I know the tires are @ 35 psi because I check them every month on all of my stuff. Some day I will simply pull the bulb on the warning light, she finds it distracting, too.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1762470
02/25/15 03:21 PM
02/25/15 03:21 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
what he said. What has the world come to that it's too much work to use a tire pressure gauge?
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1762472
02/25/15 04:22 PM
02/25/15 04:22 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
what he said.
Jsta' more junk to go wrong with the vehicle
In the cold weather here in pArAdIsE .. 3 of mine showed low ....so I went up to 37 and they are off now....
[Re: Sunroofcuda]
#1762473
02/25/15 04:28 PM
02/25/15 04:28 PM
Posts: 4,957 WI
Dcuda69
WI
No vehicle I've had has needed a TPMS reset just for adjusting pressure(some of them need a relearn after tire rotations though). You don't get to specify tire pressures... the manufacture has done that for you and entered it into TPMS software. The door placard has this info on it.36/37 psi in a TPMS system spec'd at 35 won't do squat. 36/37 in a system spec'd at 44 or 60 or ?? sure will! Was the service personnel aware of your TPMS concern or did you just assume the light would go off? Did they no you suspected a low LF tire so they could visually check the tire while in the bay? Did you question THEM about the TPMS light and why it's on? I would think a '14 is still under warranty.They could have checked it out while you were there. Have you had any tire work done? Maybe another shop damaged a sensor? Looks like you'll be heading back there... a little communication probably could have saved you a trip.
[Re: dOc !]
#1762474
02/25/15 04:32 PM
02/25/15 04:32 PM
Posts: 4,957 WI
Dcuda69
WI
what he said.
So what you're saying is the junk worked. It notified you of low pressure(especially when weather changes) and possibly help avoid a bigger inconvenience.Sucks when stuff works as designed
[Re: Dcuda69]
#1762475
02/25/15 04:42 PM
02/25/15 04:42 PM
dOc !
Florida STAYcation
Yes it did work .... but it is also going to "work again" when the temps go up ....
ONLY thing I would like having this on is a trailer ... it would have helped when I picked up a car and trailer in Fort Lauderdale and had a blow-out on Alligator Alley ...
[Re: dogdays]
#1762477
02/25/15 07:30 PM
02/25/15 07:30 PM
Posts: 5,446 So Cal
Sinitro
So Cal
Actually the TPMS system is designed to "save gas" by keeping the dullards out there aware that their tire pressure needs to be maintained. I'm not sure if it was Government mandated or just strongly suggested. It is a pain in the rear. Driving from a warm state to a cold state, the ambient temp goes down and the tire pressure decreases to below the limit, the light comes on. My wife thought it was about traction. That's what the symbol looked like to her, and she's not stupid.
I hate that it costs a MINIMUM of $5 more per tire to get tires changed on a TPMS rim.
R.
Government mandated, all vehicles built 2009 and beyond.. Their lithium batteries last up to 5 years, after that replacement is needed... U better sit down when U hear the cost!!!
Just my $0.02...;)
[Re: toplescuda]
#1762480
02/25/15 10:34 PM
02/25/15 10:34 PM
Sunroofcuda
Highland, MI.
Well, I have not physically checked the pressures yet, but the dash display is showing 37-38 per tire. I did my 80 or so mile drive today & the light is still glowing yellow. And yes, when I had it in a few days ago for the oil change, I told the guy to air-up all the tires cause the light was on. It's a lease truck & has about 8,400 miles on it now & still under warranty. Not a big deal to me, I've just never had anything on a Ram malfunction like this before & I've been leasing them since 2006.
[Re: Sinitro]
#1762482
02/25/15 11:11 PM
02/25/15 11:11 PM
dOc !
Florida STAYcation
Just my $0.02...;)
I have a loaded 05 Grand Caravan that has them. Two of them were dead when I bought it back in Jan of 2014.... I would not have minded it IF it did not "kill" the overhead console info. IF it had just been a light in the dash I would have just put a piece of tape over it. ALSO .... those 2 dead ones would interfere with the radio !!
I got four new tires on it about 4 months ago ... bought 4 new TPSM's through eBay .... 41$ !
