Page 2 of 6 1 2 3 4 5 6
Re: So...how many predator engines are out there? [Re: Monte_Smith] #1762422
02/26/15 07:46 PM
02/26/15 07:46 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The thing about dyno numbers.......is it is JUST that, a number. You go into a shop, plunk down your hard earned money, tell them you WANT a 1200hp Predator motor, you can about bet they will produce a dyno sheet that says it makes that. But the race track doesn't lie. What does it weigh and how much mph does it run. THAT tells you how much power it makes.
I love reading the knowledge you guys bring to this forum as a non drag racer, from from my observations isn't the race track the biggest liar for actual power?
There are so many posts on different variables that effect track times that even a dyno seems more accurate. Tires, springs,shocks, aero, gearing, transmission, pinion angle, track condition, altitude etc etc all effect it. Even the driver has a ton to do with it, if I was in Al's car it would have the MPH of a slant 6 powered valiant wagon and he would need to replace the drivers seat due to random stains after I was done.
Plus it really discredits other forms of racing, Boatracers572 boat and diablo's pulling truck come to mind. I put my mud racing truck into the wallace calculator one day and my poor 440 was making something like 17 horsepower, and sometimes I don't even make it the full 200 feet.
Re: So...how many predator engines are out there? [Re: CTD5.9] #1762423
02/26/15 08:10 PM
02/26/15 08:10 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
This is a good point. The thing is, most of us at this power range know how to tune our stuff to the conditions, tire size, roll out, gear etc. It's a matter of if we go through the trouble to find the ideal tune for ET and .90 racing. Guys in comp, or small tire, first to the finish line racing, don't have a choice. If they don't run on the edge, they lose.
Guys like me that put a number on the car and print time slips, don't put as much time into putting the car on the edge, more in tuning it to repeat. In that case, we don't try to put lot's of pass limiting hits the dyno as it is just a number and tuning tool.
Some guys make more runs on the dyno than at the track, even wear out engines figuring out the optimal tune.
Opinions vary, and I don't put a lot of hits on a dyno but use it to get an idea of jetting, timing, RPM range, and stop any leaks.
Re: So...how many predator engines are out there? [Re: CTD5.9] #1762424
02/26/15 08:25 PM
02/26/15 08:25 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I'm building a 672 with Predator heads. I started to go 690, but opted for the 672 because of the rod/cam interference even with a 2 inch rod journal, and a 60mm cam.
Bryant just finished the crank, but still waiting on the block. The heads have been an ongoing effort, and still not done. Offsetting the rockers makes room to make the ports as big as they need to be, which seem to be a problem with big inch motors. With tool steel rockers we can offset, and move the port wall another .175.
When, if ever finished it'll go in my RJ stratus, and I think 1300 should be doable, but only time will tell.
Trouble is, there's no real reason to be doing it. There's no class where that head would be competitive against Ford, or Chevy. Just something to try.
Re: So...how many predator engines are out there? [Re: dthemi] #1762425
02/26/15 08:47 PM
02/26/15 08:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Plenty of classes, Top Sportsman, Super Comp, Super Gas and Brackets come to mind. Just sayin
Re: So...how many predator engines are out there? [Re: CTD5.9] #1762426
02/26/15 08:56 PM
02/26/15 08:56 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Yes, getting the car down the track is important.........but is track time a liar about power?........absolutely NOT. ET the car runs is not representative of power, but MPH is. So the car can make a junk pass, but if it is making any power, it will be moving in the back half and those last few feet of the track where the mph clocks are. At a certain weight, HP should propel a car to a certain mph, that is simple math. If the engine is in the rpm range it should be, the converter slip is where it should be, it SHOULD run a certain mph range based on the power it supposedly makes.
I can run the numbers for our own drag radial car. If I input our best speed.....178 and our weight......2750, the calculators say we make around 2450hp. Based on our motor and the amount of nitrous we spray, I would say that number is very close. Now, if I input our best ET.........which is 4.16........and our 2750 weight, the calculator says just a little over 2000hp and I KNOW that is not right. ET is based on how you get the car down the track. Ours being a drag radial car we know we leave plenty on the table early as for ET, but we MAKE power, the mph and how fast we cover the back split tells me that
In general weather conditions, a 2450lb TS type car, with an engine that makes 1300hp......SHOULD run 7.30-7.40s in the 192mph range. If you look at the graph, the rpm is where it should be, the converter slip is where it should be and the car is running 185mph.......it is NOT making 1300hp. It is actually about 100 down from advertised. The math just is what it is.
I am NOT saying dyno numbers are useless. I dyno motors all the time. What I AM saying is that they are NOT the be all end all barometer of an engine, because those numbers can be EASILY manipulated, based on correction factors.
BUT, HP propels a properly set up car, at a certain weigh, to a certain MPH range. That's a true barometer. A prime example are some of the .90 class cars. They ALL run the same ET. But some run 150, some run 170. You put 20mph on another car, in the same class, at the same weight, you have WAY more power
NONE of this is a KNOCK on anybody, nor an attempt to diminish anything. You mention truck pulling. That is more about torque than raw power. So yes, you want to dyno the motor and see if the combination makes the power it should, where it should.
My observation was about the multitude of guys that tout "my motor makes X HP" because they have some dyno sheet that says it does, but the performance on the track does not come close to backing up that claim
Re: So...how many predator engines are out there? [Re: Monte_Smith] #1762427
02/26/15 10:12 PM
02/26/15 10:12 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Monte: Thank you for your explanation. I was in no way was trying to be disrespectful of you and what all drag racers do. While I still don't 100% agree I appreciate your explanation.
Sorry for derailing your thread camastomcat hopefully some more predator combo's will popup.
Re: So...how many predator engines are out there? [Re: CTD5.9] #1762428
02/26/15 11:22 PM
02/26/15 11:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As I have always said the track is the best way to humble those big HP numbers. Like pointed out mph and weight, after that it is simple math.
The ONLY exception to an that is for throttle stop cars. Yep everyones favorite subject. Anyway the farther a car is capable of running under it's index the more MPH they tend to loose. For instance my car will loose 6-8MPH running S/ST vs all out MPH. But MPH is still the best judge of HP.
Re: So...how many predator engines are out there? [Re: Al_Alguire] #1762429
02/27/15 10:22 PM
02/27/15 10:22 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I am pretty happy I didn't go to the Predator stuff after my two TS engines. 4-6 years ago when I was looking into the Predator engines the numbers people were claiming they were going to make never became reality. Saved me a lot of $$$ moving right to the 5" stuff (in the long run). If I had a Predator built back then I would have quickly realized there was no real big upgrade to my TS engine and would have still been behind 200hp at that time to the other engines in the pulling world.
Although I do know of 2 Predator engines in the pulling world that run a "super Stock" class and they do fairly well.
Re: So...how many predator engines are out there? [Re: Diablo] #1762430
02/28/15 12:11 AM
02/28/15 12:11 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I have a buddy that dynoed 1265 at 622". He wasnt happy, but it was crappy air so he was ok with it.
Re: So...how many predator engines are out there? [Re: RemCharger] #1762431
02/28/15 12:48 AM
02/28/15 12:48 AM
Salt Lake City
Salt Lake City
I have a buddy that dynoed 1265 at 622". He wasnt happy, but it was crappy air so he was ok with it. [/quote
I would have been ecstatic. What or who's dyno?
Re: So...how many predator engines are out there? [Re: camastomcat] #1762432
03/02/15 04:44 AM
03/02/15 04:44 AM
Chesterfield Twp. Mi.
John Burdine Offline
I think some may expect the same hp results as a big chevy with a head the flows close to what the Predator head flows. the big Chevy isn't stuck with a 4.80 bore space and for most a 4.5 bore. the results wont be the same.
Re: So...how many predator engines are out there? [Re: John Burdine] #1762433
03/02/15 05:01 AM
03/02/15 05:01 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The BEST Predator head, is not near as good as the BEST 4.840 spreadport Chevy head......plus you are limited on bore because of borespace. It's NOT gonna make the same power.
Monte
Re: So...how many predator engines are out there? [Re: Monte_Smith] #1762434
03/02/15 05:16 AM
03/02/15 05:16 AM
Monte
I understand, I guess what I'm saying is, if you have a Chevy head that flows the same as your Predator, the chevy would still pick up some power just because the head is over a larger bore.
Re: So...how many predator engines are out there? [Re: John Burdine] #1762435
03/02/15 05:32 AM
03/02/15 05:32 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No news here. Bore makes HP period. 4.600 bore is gonna make way more power than a 4.500 bore any day.
Re: So...how many predator engines are out there? [Re: Al_Alguire] #1762436
03/02/15 01:39 PM
03/02/15 01:39 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
So why haven't more people used these heads?
They may not make the most power but, they still make a ton.
I have a set but never used them because back when I got them 6-7 years I knew nothing about engines (still don't) and figured they would be the last set of heads I would ever need.
I eventually realized that they are way overkill for road course use.
They are a great set of heads but too bad more people never utilized them. I often wonder how far the Predators development would have gone if they were the popular head option?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: So...how many predator engines are out there? [Re: RylisPro] #1762437
03/02/15 01:51 PM
03/02/15 01:51 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What kills future development on these or ANY big block Mopar head for that matter........is the BLOCK. In this day and age of bigger is better, that 4.800 bore space is a killer. Even if you COULD make the head flow 600......the bore KILLS it. Plus many real diehard Mopar guys never embraced this head because it LOOKS like a spreadport Chevy head
Monte
Re: So...how many predator engines are out there? [Re: Monte_Smith] #1762438
03/02/15 02:14 PM
03/02/15 02:14 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Like I said I know nothing about engines, but isn't there a bunch of manufacturers that can make a bigger bore space block? KB, Indy, World, HP, custom billet, etc.?
As far as the Predators looking like a chevy for Mopar guys not using them, to me that is like having your girl looking like Kate Upton and not wanting to bang her.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: So...how many predator engines are out there? [Re: RylisPro] #1762439
03/02/15 02:21 PM
03/02/15 02:21 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Have to agree...its not the block....its simple economics.
Re: So...how many predator engines are out there? [Re: Jerry Kathe] #1762440
03/02/15 02:43 PM
03/02/15 02:43 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Could somebody build it..........sure. Has history shown enough would buy it to make it a viable investment......No. Plus that ship has sailed. Chevy guys are WAY past 4.840 stuff now and 5.0 motors are "bracket" motors these days. Mopar is too far behind and even "hardcore" guys have just gone with the flow and have Chevy "based" power plants. Too little, too late, even if somebody WOULD do it. Plus, some feel the head would look so much like whats available for "other" motors, that "what's the point" and I tend to agree.
Re: So...how many predator engines are out there? [Re: Monte_Smith] #1762441
03/02/15 09:30 PM
03/02/15 09:30 PM
hustlin hoosier Offline
Some one earlier stated bore was king, I agree we run a spread bore wedge 600-13x motor. Originally it was 4.563 x 5.00 we changed to 4.600 x 4.75 and went 3tenths faster. We can't compare dyno numbers due to a change in dyno's. Our wedge motor on Best"s dyno is at least as good as any Predator motor they have built, and I think better. We are 4.840 bore space.
