gtx trunk panel studs #1762075
02/24/15 04:39 PM
02/24/15 04:39 PM
btomasko Offline OP
btomasko  Offline OP
How would you fix or repair a few studs that broke off of the back of the panel?
Thanks 1968
Re: gtx trunk panel studs [Re: btomasko] #1762076
02/24/15 05:09 PM
02/24/15 05:09 PM
I dont know if you can cause it is white metal.
Re: gtx trunk panel studs [Re: ] #1762077
02/25/15 10:00 PM
02/25/15 10:00 PM
Illinois
SGTFURY62 Offline
SGTFURY62  Offline
Illinois
I'm in same boat with another panel. Have wondered if could grind broken studs flat and cut another stud off another panel (something more modern and available) and use panel bond to stick the new stud on? Panel bond on sheet metal is supposed to be stick them together stronger than stock. Maybe it'd work on studs?
Re: gtx trunk panel studs [Re: btomasko] #1762078
02/25/15 10:07 PM
02/25/15 10:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
An idea I've thought about is , grind the damaged area/broken stud flat with the panel.
Then drill and tap it to say a 10-24 thread and put s machine threaded stud in it
