Bearing pitting cause?
#1761835
02/24/15 02:11 AM
02/24/15 02:11 AM
Posts: 767 NW PA
V10nacuda
NW PA
Pulled my pump gas 451 out and decided to evaluate it to see what it needed.All cylinders leak down to 2 percent or 3% except for one... turned out to be 5%. mains looked so so..pulled the rod bearings and found this on both sides of the rod bearing. any ideas what caused it?
My buddy didnt think it was detonation Looking for ideas.
Re: Bearing pitting cause?
[Re: V10nacuda]
#1761836
02/24/15 03:19 AM
02/24/15 03:19 AM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi looks like condensation that did not get burned off due to not running engine long enough to boil out moisture . condensation left in the oil creates acid that eats the metal .
