Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: RSNOMO] #1761513
03/02/15 06:15 PM
03/02/15 06:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have always bought the OE material instead of the Stainless. I had heard that the hardness of the stainless created issues sometimes with getting a good seal at connections. Also, I thought, if the crappy originals lasted 35 years and 80,000 miles, surely the new ones will last longer when it is stored in a climate controlled garage and driven 1500 miles a year.
I have scotch-brited, and cleared OEM lines...
They did not hold up at all...
My experience with SS has been multiple sealing issues...
Flares not as forgiving as 'softer' OEM steel...
My experience with In Line Tube has not been good...
I'm a Fine Line fan. I have bought fuel and brake lines now from them for 3 cars and they all fit fine. I am not a fan of stainless, the first mild steel set lasted 30 years, so...
All fittings should be lubed/oiled before installation. IF YOU DON'T ON STAINLESS THEN YOU DON'T HAVE CHANCE OF MAKING THEM SEAL, IMO...aND LIKE mIKE SAID, NEED A GOOD WRENCH.
Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: RSNOMO] #1761514
03/02/15 06:24 PM
03/02/15 06:24 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Have to now agree with no for Inline....customer service sucks!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: JMCFAN] #1761515
03/02/15 09:02 PM
03/02/15 09:02 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Well it depends on how one defines best. Closest or original, nicest bends, helpful service, blah blah.
My experience FWIW - and this goes back at least 5 years, maybe closer to 10.
Goal: Performance, overkill heat reduction and flow capacity.
Need: Replace the main chassis fuel line which had some rust and maybe even porosity over the axle, but no obvious leak.
Decision: Stainless 3/8 line in stock location (plus pick up and feed, of course).
Purchased in this order for a '67 Barracuda:
1. Fine Lines, claimed to fit 67-8 B & V. Bends were somewhat collapsed, so returned. See goals if this seems extreme.
2. Classic Tube, claimed to fit 67-8 B & V. Did not fit my '67 B'cuda correctly. Cut up tubing for other purposes.
3. Inline, claimed to fit 67 B. Fit well in original location.
Is there a difference between 67 and 68 or between Barracuda and Valiant? My guess is yes. Does that mean that the people at Inline know when there differences better than the other two? I have no idea. All I can say is that they did in this one instance.
Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: Challenger 1] #1761516
03/02/15 09:55 PM
03/02/15 09:55 PM
None
71rm23 Offline
71rm23  Offline
None
Fine Lines stainless Steel brake and fuel lines here
Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: Mattax] #1761517
03/02/15 10:01 PM
03/02/15 10:01 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Ok I will elaborate. Inline fuel lines and full length brake lines fit fine. The rear end brake lines did not...now I will say that I ordered last year and am just getting to the rear end install.
When I inquired about the wrong lines was asked to send a pic and they would SELL me a set that fit...30 days to check fit etc or no return.. I will just eat it.. but will go else where.. I spent well over $500 with them.... those 2 pieces are $25..and never been installed...
Just me...
Re: Full Length Fuel/Brake Lines, Who Is The Best???? [Re: JMCFAN] #1761518
03/02/15 11:05 PM
03/02/15 11:05 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Fine lines products fit great and the customer service is just as good. I have had poor customer service with In Line. Bought some parking brake cables and the first application of the parking brake the "barrel" that is crimped to the end of the cable came off. I was getting ready for a car show and now had no parking brake with a four speed car and guess what, In Line employees could care less. Absolutley refused to address the problem until I sent the old one back. Given the circumstances I think that they should have sent another cable as I returned the bad one to expedite things. Oh well last time I will deal there.
