wire diagram #1761203
02/23/15 10:38 AM
02/23/15 10:38 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I have a 2008 ram I need the pin layout on the radio connector... I'm putting in a New radio it stay on without the key on I need to wire it up differently or can someone tell me what I did wrong... I did get the wire connect for to hook it with my harness...
Re: wire diagram [Re: BigTerry] #1761204
02/23/15 06:46 PM
02/23/15 06:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I don't have what you're looking for but I do have a suggestion. make sure the drivers side door switch isn't sticking. I just went through this with my sons car and couldn't figure it out until I noticed his dome light wasn't coming on....
Re: wire diagram [Re: BigTerry] #1761205
02/23/15 06:53 PM
02/23/15 06:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
the adapter connector usually has loose ends you solder to the new radio's wires. You sure you didn't miswire that? Cause I have yet to run across one that was not setup right, but I haven't done an 08 Ram either.
Don't be the exception.
Re: wire diagram [Re: Supercuda] #1761206
02/23/15 06:58 PM
02/23/15 06:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I gotta agree with this! I have installed a ton of radios in a bunch of different stuff and never had a problem with a NAME BRAND installation kit.
Re: wire diagram [Re: BigTerry] #1761207
02/23/15 07:12 PM
02/23/15 07:12 PM
AL
jglen490 Offline
jglen490  Offline
AL
Maybe this will help. Just go by which type connector your 2008 has:
http://installdr.com/Harnesses/DCP-Wiring.pdf
Re: wire diagram [Re: jglen490] #1761208
02/24/15 10:39 AM
02/24/15 10:39 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I connected the wire per color code on the new adapter and harness for the radio I couldn't get any power.... I next connected the yellow and red and I got power but it on without the key on... I may did it backward or something... Thanks for the link...
Re: wire diagram [Re: jglen490] #1761209
02/24/15 11:40 AM
02/24/15 11:40 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
my radio got two connecter on it one big one and one small one.. I guess the small one is for the sirus radio??
Re: wire diagram [Re: BigTerry] #1761210
02/24/15 12:32 PM
02/24/15 12:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
don't know about yours but on my kids car the 'extra' wire harness was for the warning chime which came through the drivers side door speaker. replacing the radio disabled that but the wiring kit I bought came with an adaptor that puts out the 'chime' sound when the lights are on, key in ignition and seat belts.
Re: wire diagram [Re: mikemee1331] #1761211
02/25/15 11:19 PM
02/25/15 11:19 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
OK I got a current wire diagram of harness in the truck... My question is not the same as my truck connector when you look at the connector there two gray wire with a red stripe On one which is the main power to the radio then there a few blank spot. But on the new adapter the red acc wire does not have a wire to mate to. To get the radio to work I connected the red with the yellow wire ...what did I do wrong?
Re: wire diagram [Re: BigTerry] #1761212
02/26/15 03:42 PM
02/26/15 03:42 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Re: wire diagram [Re: BigTerry] #1761213
02/26/15 09:26 PM
02/26/15 09:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
just a suggestion but you might ask the moderators to move this thread over to the truck section. you might have better luck getting an answer
Re: wire diagram [Re: mikemee1331] #1761214
02/26/15 11:35 PM
02/26/15 11:35 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
True it been a long since I been on here I fogot ..
Re: wire diagram [Re: BigTerry] #1761215
02/27/15 08:33 PM
02/27/15 08:33 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
could one of the mod move my thread to the truck section please!
Re: wire diagram [Re: BigTerry] #1761216
02/28/15 09:55 PM
02/28/15 09:55 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you have to message one of them . at the bottom of the page in the 'extra information' you will see a list of moderators that are on the site. just send one a message with the title of your thread and where they can find it.
beware - they might ask for snacks so be prepared!
Re: wire diagram [Re: mikemee1331] #1761217
03/02/15 09:49 AM
03/02/15 09:49 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Oops
