Re: 360 cast crank ,balancing
[Re: Tobbe]
#1761107
02/23/15 03:08 AM
02/23/15 03:08 AM
Posts: 248 Sweden
Tobbe
Sweden
[Re: Tobbe]
#1761108
02/23/15 03:16 AM
02/23/15 03:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You better get it balanced.. looks like the OD of the crank has been turned down.. and I think I see a spot on the side of the counter weight that looks like its drilled... JMO
[Re: Tobbe]
#1761112
02/23/15 07:13 AM
02/23/15 07:13 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Factory balance had the weights in the converter, not the flex plate.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1761113
02/23/15 07:38 AM
02/23/15 07:38 AM
Posts: 248 Sweden
Tobbe
Sweden
yes the LA have ,could be that pre owner had a converter whit weights magnum have on the flexplate
