06 ram hood props #1759318
02/20/15 07:38 PM
02/20/15 07:38 PM
md
mopars4ever Offline OP
md
My hood props worked fine until this arctic cold weather came though. Now the hood won`t stay up. Is it normal for cold weather to cause this or did they just go bad.
Re: 06 ram hood props [Re: mopars4ever] #1759319
02/21/15 01:11 AM
02/21/15 01:11 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Cold weather makes the gas lighter. You most likely only have one bad. Even on a good day the hood wont stay open with one bad one.
Re: 06 ram hood props [Re: NITROUSN] #1759320
02/21/15 01:37 AM
02/21/15 01:37 AM
md
md
Do they just pop off or is their a retainer clip? I never had one off before.
Re: 06 ram hood props [Re: mopars4ever] #1759321
02/21/15 01:54 AM
02/21/15 01:54 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
clip on each end. get a board to hold the hood open high. pop the clips with a screwdriver. replace with new ones. should take longer to cut a board to fit the hood to hold it open, than it will to replace the lifts.
Re: 06 ram hood props [Re: Golden-Arm] #1759322
02/21/15 02:20 PM
02/21/15 02:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just get a second set of hands to hold the hood while you pop them off.
Re: 06 ram hood props [Re: NITROUSN] #1759323
02/21/15 03:05 PM
02/21/15 03:05 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Pair of vise grips.
Don't put off changing them. Cost me a radiator and a new a/c condenser fan assembly when the hood came crashing down and there was some stuff in the way.
