Re: Pso heads
[Re: jkwedge540]
#1759264
02/20/15 08:27 PM
02/20/15 08:27 PM
Posts: 289 Lowes
steve660
Lowes
Have you tried Muscle Motors?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: Pso heads
[Re: steve660]
#1759265
02/20/15 10:03 PM
02/20/15 10:03 PM
Posts: 55 Nebraska
TT5 Valiant
Nebraska
Good luck with Muscle Motors! I called 3 times in the beginning of December and I'm still waiting for Mike to call me back.
Re: Pso heads
[Re: go green]
#1759268
02/21/15 03:14 AM
02/21/15 03:14 AM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Just do the predator head , its a way better platform and you might be able to get a set before November if you are lucky.
![](/ubbthreads/images/graemlins/iagree.gif) Don't waste your time searching for a white elephant
Re: Pso heads
[Re: jkwedge540]
#1759271
02/21/15 07:41 PM
02/21/15 07:41 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Well pistons are the part that changes, and you will need to for the PSO as well anyway so I guess I don't see the issues.
Re: Pso heads
[Re: Gary Robbins]
#1759273
02/21/15 09:03 PM
02/21/15 09:03 PM
Posts: 289 Lowes
steve660
Lowes
Muscle Motors is doing a set for me. I think they do their own CNC porting.
Re: Pso heads
[Re: steve660]
#1759274
02/21/15 10:17 PM
02/21/15 10:17 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
I would be shocked if Muscle Motor did any CNC porting of anything. As far as I know they send everything out... To Modern I think. Correct me if I am wrong, but pretty sure I am not.
Re: Pso heads
[Re: old yeller]
#1759276
02/22/15 02:08 AM
02/22/15 02:08 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Pso heads should be re-named POS...those heads are not work friendly and r really not that much faster than a indy head...for the cost...and the pain in the azz that they are....but what do I know
Do tell......
Re: Pso heads
[Re: jkwedge540]
#1759278
02/22/15 12:29 PM
02/22/15 12:29 PM
Al_Alguire
Las Vegas
Well I have two set both between 475-480 on a number of different benches. One motor is just shy of 1100 at 525" with a fairly small cam. The other we will see hopefully next week. Both sets done by cylinder head specialists(rear non Mopar shops) that started with raw castings. IMO not worth the expense to go to a PSO if you over an MC or B1 for what is a potential of 25ish CFM.
BTW I know I hear it all the time no way those heads flow that much or make that power. But the car seems to run a representative number. I am doing a Predator deal now and will have some numbers eventually. Those heads are at 540-550cfm on the same bench as my MC stuff. We will see what kind of power they make here soon enough.
Re: Pso heads
[Re: Al_Alguire]
#1759279
02/22/15 01:23 PM
02/22/15 01:23 PM
Posts: 515 geezer acres rest home
dakotawilly
al,please post a pic of the port design of the b1 heads if you have one,i believe you said it was an oval design.seems you are getting more than average flow on yours.curiousity is killing me.....
SFI 25.5 depends,no leak,even at 213 mph....
