Re: 440 source.com
[Re: Moparmick]
#175842
12/26/08 11:16 PM
12/26/08 11:16 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Anyone use them ? reliable? do we get discount from them? Mick
I have bought a stroker kit, W/P housing, oil pan, timing chain/gears, flexplate, and various bolts from them. All seemed to be as advertised and were good quality. Their page is also VERY informative.
The only thing I don't care for is they don't have web ordering so you have to call during their business hours. It's a small thing but I would think they could start the whole e-commerce thing by now...
That aside, they seem knowledgeable and were polite on the phone. No discounts as far as I know of....
Re: 440 source.com
[Re: chrisf]
#175848
12/27/08 12:47 PM
12/27/08 12:47 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
My goddness moparmick, have you been living under a rock? There are electronic fist fights weekly over the source. Pick your fighting style and good luck!
Keep old mopars alive.
Re: 440 source.com
[Re: Buzzrider]
#175851
12/27/08 07:18 PM
12/27/08 07:18 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Man I love those torque numbers what cam did you use ? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 440 source.com
[Re: fourgearsavoy]
#175853
12/27/08 07:46 PM
12/27/08 07:46 PM
Posts: 26 Blaine, MN
Buzzrider
Blaine, MN
Build:
-68 383 block -4.310 Bore(.060 over) -440 Source stroker kit(4.250 stroke, -20 dish pistons, upgrade to I beam connecting rods) -10.4 to 1 compression ratio(pistons machined -.010) -Mopar Aluminum heads(straight plug) 2.14/1.81 -Comp Cams XE290S -Crane Aluminum roller rockers 1.5 -106* LSA (recommended-still need to make sure. Dyno guy did not know) -Holley Street Dominator intake -AED 950 Race carb DP w/ 1" spacer -Summit Mopar Distributor -Hemi oil pan with 3/8 pick up
Re: 440 source.com
[Re: Buzzrider]
#175854
12/27/08 08:07 PM
12/27/08 08:07 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Build:
Are the out of the box or were they ported? Those are great numbers.
