restorations marking info? #1758212
02/19/15 01:46 AM
02/19/15 01:46 AM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
I am restoring a 69 Hemi car. Had marking on fire wall , front suspension and rear end. My question is. Where caN I get info on all the correct markings and locations. thanks
Re: restorations marking info? [Re: stuman] #1758213
02/19/15 02:00 AM
02/19/15 02:00 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From your car.
No two cars are exactly the same, so document what you find & put it back that way.
Anything added would be a custom, not a restoration.
Re: restorations marking info? [Re: Alaskan_TA] #1758214
02/19/15 01:22 PM
02/19/15 01:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Putting an inspection mark on your car just because there is one like it on another car...is not the way to go about it. Only put back the marks you found while disassembling your car.
Re: restorations marking info? [Re: burdar] #1758215
02/19/15 03:00 PM
02/19/15 03:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
xx2
Re: restorations marking info? [Re: ScottSmith_Harms] #1758216
02/19/15 11:45 PM
02/19/15 11:45 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
What if your car was torn down and totally void of all markings when you got it? Weren't there markings all cars got on the transmission, differential, brake booster etc?
