Gen 3 Hemi valve cover interchange? #1758201
02/19/15 12:34 AM
02/19/15 12:34 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Do all the Gen 3 valve covers interchange between all the heads?
If not can you explain what you have found?
69 Dart
Re: Gen 3 Hemi valve cover interchange? [Re: onig] #1758202
02/19/15 12:42 AM
02/19/15 12:42 AM
MN
hemidup Offline
hemidup  Offline
MN
You can use the later Eagle/Apache valve covers for every application. The early 5.7/6.1 are only interchangeable between the 2. The spark plug towers are the same height for all, however the Eagle/Apache have taller valves so the rockershafts sit higher thus the "camel humps" in those valve covers.
Edit: Also the 03-05 5.7 used the waste spark system requiring cross over spark plug wires vs the 06 and newer using coil over plugs like the 6.1.
Re: Gen 3 Hemi valve cover interchange? [Re: hemidup] #1758203
02/19/15 01:06 AM
02/19/15 01:06 AM
Canada
onig Offline OP
onig  Offline OP
Canada
I have the 6.1 Apache heads.
So anything after 06 should work, correct?
69 Dart
Re: Gen 3 Hemi valve cover interchange? [Re: onig] #1758204
02/19/15 01:50 AM
02/19/15 01:50 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
no, everything after 09 does.
Mopar to the bone!!!
Re: Gen 3 Hemi valve cover interchange? [Re: 72Swinger] #1758205
02/19/15 08:57 AM
02/19/15 08:57 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Alright, thanks for that clarification.
69 Dart
Re: Gen 3 Hemi valve cover interchange? [Re: onig] #1758206
02/19/15 10:42 AM
02/19/15 10:42 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
You have the 6.4 Apache
Re: Gen 3 Hemi valve cover interchange? [Re: MattW] #1758207
02/19/15 12:34 PM
02/19/15 12:34 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Not 6.1?
69 Dart
Re: Gen 3 Hemi valve cover interchange? [Re: onig] #1758208
02/19/15 03:37 PM
02/19/15 03:37 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Not 6.1?
The Apache came out with the 6.4. in 2011
The eagle came out with the new 5.7 in 2009
The first gen 5.7 and 6.1 did not have names associated with them.
Matt
