88 Dakota wheel studs #1757086
02/17/15 11:26 PM
02/17/15 11:26 PM
ky, usa
littlejohn44 Offline OP
ky, usa
Does anyone know what size wheel studs are on the front? I have to go longer for my weld wheels.I know they are press in but what size is the press in part? What have yall been using for 2-3 inch studs?
Re: 88 Dakota wheel studs [Re: littlejohn44] #1757087
02/18/15 03:45 AM
02/18/15 03:45 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: 88 Dakota wheel studs [Re: Golden-Arm] #1757088
02/18/15 10:48 AM
02/18/15 10:48 AM
ky, usa
ky, usa
i searched oriellys and summit and they had 3 different diameters. That matches one of oriellys, What brand long studs do yall use?
Re: 88 Dakota wheel studs [Re: littlejohn44] #1757089
02/18/15 03:08 PM
02/18/15 03:08 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
sorry, can't help you. i run stock length studs on mine.
Re: 88 Dakota wheel studs [Re: Golden-Arm] #1757090
02/21/15 12:27 AM
02/21/15 12:27 AM
ky, usa
ky, usa
Have you used this this stud from them? I have got 2 diffrent sizes and i am not for sure what size is right? They say .568 summit says .673 ? Any one know?
Re: 88 Dakota wheel studs [Re: littlejohn44] #1757091
02/21/15 01:49 AM
02/21/15 01:49 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i broke a stud recently on the dakota. i put a lugnut on another stud, and knocked it loose. i took that to the parts store, and matched it. stud was like, 2 bucks. take one with you, and match it with a longer one, that has the same thread pitch and mounting hole size.
