How to use Summit code #1757050
02/17/15 10:54 PM
02/17/15 10:54 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I was just going to make a order from Summit on line and I did not see where to put the source code on the checkout page. Do I have to call the order in to use it?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: How to use Summit code [Re: D-50] #1757051
02/17/15 11:04 PM
02/17/15 11:04 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I got a 10% discount code from a member here and on the checkout page it ask sales person ID then source code. I have a 10 digit # where do I put that number?
Thanks........
Re: How to use Summit code [Re: D-50] #1757052
02/17/15 11:29 PM
02/17/15 11:29 PM
VA
VPofGreen Offline
VPofGreen  Offline
VA
Should be area right above that... Summit bucks/certificate number? + exp date .
Re: How to use Summit code [Re: VPofGreen] #1757053
02/17/15 11:45 PM
02/17/15 11:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
And numbers have to be EXACTLY as given.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How to use Summit code [Re: pittsburghracer] #1757054
02/17/15 11:50 PM
02/17/15 11:50 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
Source code is the # at the top left on the back cover of the catalog.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: How to use Summit code [Re: VPofGreen] #1757055
02/17/15 11:51 PM
02/17/15 11:51 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thank you very much.........
Re: How to use Summit code [Re: D-50] #1757056
02/18/15 12:49 AM
02/18/15 12:49 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
If you are in the PRO-SHOP you cant use the 10% discount any longer. You can use it if you log-out and check out as a guest. 10% is usually a much bigger discount than PRO-SHOP. Especially on slicks.
Summit discounts available [Re: qwkmopardan] #1757057
02/19/15 07:07 PM
02/19/15 07:07 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
If anyone is interested, I have about 8 discount codes to give away. They expire the 22nd, so you would have to use them soon.
PM me if you're interested.
