Re: overdrive trans question
[Re: wyldebill]
#1757015
02/19/15 08:14 PM
02/19/15 08:14 PM
Posts: 12,252 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A LU converter can be built, but there are limitations on what can be done with it compared to the non-LU. Call PTC, tell them what you are wanting the converter to do and they can tell you if you can get there with the LU.
Master, again and still
[Re: wyldebill]
#1757017
02/19/15 10:32 PM
02/19/15 10:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
im not trying to run wot in overdrive or lu. is there not a stall converter available for a lu?if not i guess ill look into building a ford trans and controler. i know that i can build a 5r110 to work.
If you dont plan on WOT then the stock conv works.. otherwise the conv can get pricey.. the problem is the space between the block and the pump to get any size conv in there
