Gen 3 Hemi Heads - Aphache L&R ? #1756986
02/17/15 08:30 PM
02/17/15 08:30 PM
Canada
onig Offline OP
onig  Offline OP
Canada
I am looking at these Apache cylinder heads, left and right, and they are side specific.
What I have figured out (if I am correct) is;
-Exhaust bolt pattern is different, there is boss material there to drill and tap to make them both the same.
-the right head exhaust flange has an added hole as well as a threaded hole. This I have no idea as I don't have an engine to look at. Does anybody know what they are for? Lower head left side.
-Next to the intake ports are cut-outs. I take it that one is for oil filling, what is the other for?
To make these heads work for either side the exhaust bosses would need to be drilled and tapped.
Also each head would need to be drilled for oil return at the back of the head. It seems like there is enough material there to do this.
Any thoughts, comments or answers would be appreciated.
69 Dart
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: onig] #1756987
02/17/15 08:46 PM
02/17/15 08:46 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
1. EGR passage
2. Crank case ventilation
If you like drag racing, support your local track.
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: CHAPPER] #1756988
02/17/15 08:57 PM
02/17/15 08:57 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Crankcase ventilation, makes sense.
EGR, this hole is not drilled through to anything. But I believe you as to it's location as well as some heads that I was looking at online asked for EGR or Non-EGR.
Obviously these ones are Non-EGR heads. Thanks.
What about the drilling of the oil return to make these heads work on either side of the engine.
Have you done it?
69 Dart
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: onig] #1756989
02/17/15 08:59 PM
02/17/15 08:59 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Also is there anything else that makes these side specific that I may have missed?
69 Dart
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: onig] #1756990
02/17/15 09:15 PM
02/17/15 09:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have not attempted to make the heads work on either side. I have only built a couple of these Gen 3 engines and "still learning" is an understatement!! I am always watching the Gen 3 topics and learning as much as I can and willing to share what little I know about them.
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: CHAPPER] #1756991
02/18/15 01:18 AM
02/18/15 01:18 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Thanks Chapper,
your sharing has learned me a bit.
69 Dart
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: onig] #1756992
02/18/15 01:25 AM
02/18/15 01:25 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I watch these gen III threads also because I plan on going Gen III in the future, sooner if I blow up this magnum motor
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: onig] #1756993
02/19/15 01:38 AM
02/19/15 01:38 AM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Any particular reason you want to use the same head L/R (ported, better valves/springs, etc)?
If it came down to it, I'd be tempted to keep any parts off (if they are better than stock) of one of the heads and sell it and put those funds into the correct correct head, or sell the whole head and buy the correct head for the side instead of investing all the time and effort (and getting it machined, threaded correctly, etc) into finding out if the other head could possibly be converted to use on the other side.
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: Gen 3 Hemi Heads - Aphache L&R ? [Re: StricNine] #1756994
02/19/15 09:00 AM
02/19/15 09:00 AM
Canada
onig Offline OP
onig  Offline OP
Canada
No particular reason.
Just if down the road if I needed the heads to fit either side I could do it if need be.
I am learning as I go along.
69 Dart
