Gen 3 hemi rocker shaft size #1756820
02/17/15 06:14 PM
02/17/15 06:14 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Does anybody know what it is or can measure it for me.
I want to make a spring compressor tool.
69 Dart
Re: Gen 3 hemi rocker shaft size [Re: onig] #1756821
02/17/15 08:40 PM
02/17/15 08:40 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
.864" is what mine measures. I was in the process of building one too, but only had .750" stock available, so that is what I used to start my build. Didn't want it oversize and break the shaft mount bosses. I didn't finish my tool. I was hoping to not have to remove the heads,,but after the motor got here and a leak-down test,,I have a cylinder with excessive ring leakage, SO, I will use my off head tool.
If you like drag racing, support your local track.
Re: Gen 3 hemi rocker shaft size [Re: CHAPPER] #1756822
02/17/15 08:56 PM
02/17/15 08:56 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
22mm
Re: Gen 3 hemi rocker shaft size [Re: TrWaters] #1756823
02/17/15 11:44 PM
02/17/15 11:44 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Thanks guys.
69 Dart
