Re: Anybody running a BCR aluminum main cap & girdle set up
[Re: Jerry]
#1756077
02/16/15 07:13 PM
02/16/15 07:13 PM
Posts: 515 geezer acres rest home
dakotawilly
the web site seems a bit confusing,i clicked on it and there didnt seem to be any info on the girdle kit or anything related.needs to be some hint of where to go or at least some info on the main caps and kits.
SFI 25.5 depends,no leak,even at 213 mph....
[Re: Jerry]
#1756079
02/16/15 07:21 PM
02/16/15 07:21 PM
dakotawilly
that one works....bcrproducts.com,the other one,sdconcepts has no info on it about the caps,girdles,etc...
[Re: Jerry]
#1756080
02/16/15 10:42 PM
02/16/15 10:42 PM
Posts: 292 NY
challenger451ci
NY
girdle info is still up at www.bcrproducts.com
I know there are a lot of variables, but what power level would you rate the girdle system for on a low deck?
[Re: Jerry]
#1756082
02/17/15 03:43 PM
02/17/15 03:43 PM
Posts: 292 NY
challenger451ci
NY
That's more what I was looking for, some real world examples of what's working. I know it's impossible to give an exact hp rating with all the variables that can cause you to run over the crank on the big end. My thought is to do a 3.900" stroke low deck with Indy SR heads and build it fairly light, possibly with aluminum rods and the BCR girdle system. I'd want to hit it with roughly 350hp of spray eventually. I tend to be pretty conservative with tunes and take incremental steps. I've managed to keep my 451 stock crank and block together for several seasons with just a girdle and stock caps on a 300 shot. Something tells me it's on borrowed time though! Sorry to Hi-jack the thread...
[Re: pittsburghracer]
#1756084
02/17/15 04:36 PM
02/17/15 04:36 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
I wish all racers kept accurate records like you, I[m sure some of the ones that use our products do and they might even be running faster. unfortunately I can't go and collect data on everybodys combination just to help justify selling $700 parts.
if you had zero failures running stock caps and no girdle and had that many passes than that's a tribute to your machinist and you putting a great block together with some luck thrown in that nothing cracked up sooner than expected or you didn't lose the bottom end and oil down a track.
whenever you stress components past their design limits like every racer does, then you will always be on borrowed time. this product is like insurance, you don't know you need it until you do, and when you got it your glad you did. can you race with out it? sure. I can also race with a bad tune and too much nitrous. can you do it? sure, will it sure, maybe once or twice if you catch it.
everybodys combo will be different so its impossible to say that you'll be okay without a girdle and you definitely need one. if you don't want to run one. don't. on the other hand if you want the best insurance to help keep it all together call me.
