Ever had to shim EBody door hinges?
#1755849
02/16/15 02:28 PM
02/16/15 02:28 PM
Posts: 755 Oregon
moparmedic
I have a 73 Challenger that was bought as a project. I noticed that the doors aren't aligned very well and when I went to adjust the passenger side there were washers used as shims behind the hinges on the door side. Same on the driver's door. I have built a few E Bodies but never had to use shims there or on any hinges on any mopar as far as I can recall. I was looking for major frame damage that would cause alignment issues but nothing looks scary to me. The car has had some bumps and bruises in its life and the roof had a lot of work done to it. Anyway just wondering if any of you have had to shim your door hinges? Thanks!
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
Re: Ever had to shim EBody door hinges?
[Re: MoparforLife]
#1755851
02/16/15 03:06 PM
02/16/15 03:06 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
Are you sure that someone didn't shim the hinges rather than replace worn hinges or bushings??
Sounds like the hinge pins/bushings are worn. Put a jack under the door and GENTLY raise the door and see if there is a lot of slop visible in the bushings.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
[Re: RTDaddy]
#1755852
02/16/15 03:22 PM
02/16/15 03:22 PM
Posts: 755 Oregon
moparmedic
Hinges seem tight. I have only messed with the passenger side. As you tighten the lower hinge up against the body without shims it pulls the door forward and down in back and opens up the door gap a little wider than it should which is weird. I may need to get this on a frame rack and make sure the foundation is straight. I think I will try a different set of hinges first though.
[Re: screamindriver]
#1755855
02/17/15 01:02 AM
02/17/15 01:02 AM
Posts: 755 Oregon
moparmedic
Good point, I'll check that out. Thanks.
[Re: moparmedic]
#1755856
02/18/15 12:22 PM
02/18/15 12:22 PM
Posts: 755 Oregon
moparmedic
I was able to get the passenger door lined up properly. I don't think it was a frame issue at all but I do think this car must have had a door gap issue from the factory. The driver's side also had a bunch of shims on the lower hinge which I removed and the door aligned just fine without any shims. Weird...Just someone who didn't know how mopar doors are aligned I guess. So problem solved.
[Re: moparmedic]
#1755858
02/18/15 02:39 PM
02/18/15 02:39 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Are the quarter panels original? If someone replaced them without using the doors to line them up, that could make a big mess.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1755859
02/19/15 02:08 AM
02/19/15 02:08 AM
Posts: 755 Oregon
moparmedic
I took all the washer (shims) out. The quarters are original. This is an incredibly solid non rusty original car. I did find a welded spot on the frame forward of the shock tower so I am convinced that it has been hit and pulled back into shape. I hung all the sheet metal back on it and everything lines up but it will get a trip to the frame shop for good measure.
