Brakes on my RAM 2500
#1755319
02/15/15 09:35 PM
02/15/15 09:35 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
Hello, I have a 2004 Dodge 2500. The brake pedal goes to the floor. master brake cyl.gone? is it a temp thing with the cold? no leaks..
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Brakes on my RAM 2500
[Re: stumpy]
#1755321
02/15/15 10:36 PM
02/15/15 10:36 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Take a look underneath for a leaking brake line...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: sixty7gtx]
#1755324
02/15/15 11:07 PM
02/15/15 11:07 PM
RapidRobert
Not ABS correct? (not sure if that changes things dramatically but I want no surprises & I dont know that system). any recent brake work/parts changed? Just one day it went to the floor? (1) "bench" bleed the MC on the vehicle (put a block under the pedal to keep pedal travel to it's normal range that it (worn bore length area) is used to by guestimating normal pedal height when depressed & be conservative). (2) reconnect 2 MC lines & bleed all 4 corners. if still bad then rebuild/purchase a new/rebuilt MC
[Re: RapidRobert]
#1755325
02/15/15 11:29 PM
02/15/15 11:29 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
my '06 has hydro boost. is that because it's a cummins with a turbo and isn't always under manifold vaccum? (is yours a hydroboost?)
No idea what hydroboost feels like when it goes bad. does a lack of pressure from the Power Steering pump cause a hard or soft pedal? (I guess I need to go out and pump my brakes with the engine off to see what happens...haven't done that yet, I just assumed it was like any other brake system where the pedal gets hard due to loss of power assist)
my first guess would be that something went out in the master, maybe a seal on the piston or the bore has corrosion and the fluid is bypassing?
**Photobucket sucks**
