Page 3 of 3 1 2 3
Re: Starting problems 71 Challenger [Re: Wiggy] #1753934
02/20/15 02:54 PM
02/20/15 02:54 PM
pa.
dan9 Offline
dan9  Offline
pa.
Can you flip the copper washer over? Can you rotate the positions of the contacts that touch the washer? That used to fix a lot of GM starters.
Re: Starting problems 71 Challenger [Re: dan9] #1753935
02/20/15 06:06 PM
02/20/15 06:06 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Tried flipping the washer, I also tried cleaning the faces to make sure they were clean, then I tried giving them a slight rub with some fine wet and dry.
The thing I don't get is if I push the contacts down with my pliers, the motor spins up no probs but as soon as the solenoid pulls it down, nothing. I wonder if its something mechanically stopping it spinning once the solenoid is energized?
I am heading out to the garage again after breakfast to investigate further.
Re: Starting problems 71 Challenger [Re: Wiggy] #1753936
02/20/15 06:51 PM
02/20/15 06:51 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I would thinkit was being stopped it would buzz and get hot fast....I bet the solenoid is just not pulling hard/far enough to get good contact.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Starting problems 71 Challenger [Re: Wiggy] #1956935
11/24/15 03:39 AM
11/24/15 03:39 AM
Central Coast, Ca
Code3 Offline
Code3  Offline
Central Coast, Ca
Did you figure it out yet? I'm in a similar situation. Same click. My starter tests fine, I replaced the relay and I've had the battery charged. Next is to replace the positive cables. It's so frustrating.
I started it once. Drove to the store and then got back in it to go home and then it just clicked. It's the worst sound on the planet.
Re: Starting problems 71 Challenger [Re: skicker] #1971136
12/16/15 11:08 PM
12/16/15 11:08 PM
Tennessee, USA
E
eagles Offline
eagles  Offline
E
Tennessee, USA
If its an automatic, check the netural safety switch on the transmission,it could be bad
Page 3 of 3 1 2 3
