Page 2 of 4 1 2 3 4
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: GTX MATT] #1753573
02/13/15 10:15 PM
02/13/15 10:15 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Not trying to troll you here but I don't think you would have had the clearance issue if you were running Harland Sharp rockers. They don't have a gentle radius like the Hughes pieces. They cost literally 2X + as much though
Not trolling at all. I was going to go T&D or Jesel on one of my identical 511" short blocks so that will be next. I was also going to do another set of Victors but am pretty interested in either -1's or something comparable. I'd like to see some detail shots of the HS offset rockers for the Victors if anyone has any. I was not super impressed with the fit and finish of the Hughes rockers but figured I'd see how they work out. I am also going to replace the adjusters with some Smith Brothers stuff. Should have just bought the T&D's at this point. We shall see how it works out.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: dvw] #1753574
02/13/15 10:17 PM
02/13/15 10:17 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Wouldn't take a free pair of Victors. I can't believe in this day and age that a major company could not only design but build a part that is so screwed up. Guess they never heard of CAD
Doug
Thank you! I keep saying that this "race oriented" cylinder head has really got one over on me and people make excuses for Edelbrock. I'm not excusing anyone. If I turned stuff like that out at work my customers would burn me at the stake lol.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753575
02/13/15 10:20 PM
02/13/15 10:20 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
This weekend I am going to cut up an old set of valves, drill and tap the head portion and weld a 1/4"x20 tpi bolt to the stem to make some adjustable length mockup valves for my Victor heads, so I could mockup the rocker arm height for the max wedge rocker arm blocks. I just need to check if my old valves (from my B1 B/S heads) are 11/32" or 3/8"?
Be careful using the rocker arm shims. I'm not sure if that is why I split the center rocker stand on my old set of victor heads.
I will say this new set looks like a better casting quality than the old set.
Please let us know what you find. I was looking up valves and the intake was a shelf part but finding a long enough exhaust valve would be tough. I don't understand why they don't make the exhaust valve a little longer than the intake to make up for the wider margin to face distance on the exhaust. Am I missing something here?
I know this seems overboard to some of you but I'm trying to drive this thing as well as track time so getting it right the first time is very necessary in order to have fun at this.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753576
02/13/15 10:43 PM
02/13/15 10:43 PM
gregsdart Offline
gregsdart  Offline
I would never shim rocker shafts just on what little I know about the stresses they create. simply put, in order to not put all the load on the outer edge of the rocker stand, the shims would have to be thinner at the edges than the center. To see this, all you need to do is cut a piece of tubing length wise into 1/3s and stack them. The problem shims create will become obvious.
I would think that in most cases where a fairly high lift roller is going to be used, lowering the rocker stands might be needed rather than shimming anyway?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753577
02/13/15 11:18 PM
02/13/15 11:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It looks like a valve that is around 5.5" would work good? The valve I modified was 0.200" from the retainer lock to the tip, and the Edelbrock valve are 0.250", but the 5.5" figure takes the 0.050" into account.
I need to take the heads, rockers, and stuff to the cylinder head guy I use and see what he thinks. He is a Manely valve dealer and got me a deal on severe duty valves for my B1 B/S heads.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: gregsdart] #1753578
02/14/15 12:31 AM
02/14/15 12:31 AM
USA
B3RE Offline
B3RE  Offline
USA
Well, I did the math today for the OP's kit, and no, the shafts do not have to go down. They still need to go up, and there should be no clearance issues with any of the retainers.
Also, I don't make shims. Shims are flat stock. I make shaft spacers from billet bar stock with proper radii. They aren't stressing anything.
This saga is going to have a happy ending, as far as the rocker geometry is concerned.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753579
02/14/15 02:54 AM
02/14/15 02:54 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Now to my question...why?
Uhhhh... 'cuz somebody effed up?
I'll check my Hughes offset intakes & standard exhausts and see if there is a similar issue, but I don't recall noticing anything wrong when they've been mocked up on a head before.
Just spent some time giving my Hughes rockers (1.6 offset int, 1.5 offset int, 1.5 std exh) a close and mine are all consistent w/ respect to roller pivot location. They all look basically like your offset intake, not your exhaust (which appears to have had the roller pin installed too low in the body).
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753580
02/14/15 12:36 PM
02/14/15 12:36 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I don't have any pics myself, but the ones HS has on their website look to have the exact same profile as the standard offset rockers they sell. I had a similar issue with rockers I was going to try to run on my build and ended up going to the HS rockers Mancini sells.
I was actually pretty annoyed too because I already had the first pair of rockers and if I knew I was going to have to buy rockers I'd have bought Victors since the offset Hughes rockers are the same price. Looks like in the end I dodged a bullet there.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: BradH] #1753581
02/14/15 12:46 PM
02/14/15 12:46 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I see on Hughs' installation instructions, they address the shim
problem with instructions to trim the ends to avoid undue side
stress on the rocker pedestals.
Shims to my feelings are problematic because of the way we're introducing something into the original design that is
possibly degrading it.
My
Joe
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: Jeremiah] #1753582
02/14/15 01:38 PM
02/14/15 01:38 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Here's a couple
Also, here's a link to a past thread with some pics. https://board.moparts.org/ubbthreads/show...part=1&vc=1
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753583
02/14/15 01:40 PM
02/14/15 01:40 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
nuther
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753584
02/14/15 01:43 PM
02/14/15 01:43 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753585
02/14/15 01:46 PM
02/14/15 01:46 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753586
02/14/15 02:30 PM
02/14/15 02:30 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What is the offset on the H&S rockers? I think the ones for the INDY heads are 0.800"?
My T&D rockers for the MW Victors are 0.725" offset, and I think the standard port Victors are a 0.600" offset?
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753587
02/14/15 02:37 PM
02/14/15 02:37 PM
Lynnwood WA
MikeStahl Offline
MikeStahl  Offline
Lynnwood WA
Intakes r .650 offset
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753588
02/14/15 02:42 PM
02/14/15 02:42 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
HS Intake offset for the standard or MW Victors is .650" I am running MW. I'm also using Comp 87019-16 lifters with .210 PR seat offset on intake. I hindsight I should have used the standard 829-16 solid body lifters and just done a little more clearencing for pusrods.
http://www.harlandsharp.com/mopar_vr_indy.htm
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753589
02/14/15 02:45 PM
02/14/15 02:45 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753590
02/15/15 06:17 PM
02/15/15 06:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
what is wrong with the offset lifters?
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: 451Mopar] #1753591
02/15/15 07:21 PM
02/15/15 07:21 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
The 87019s have an oil band and, I beleive, have a bit shorter body than the 829s. Once together and running, I wasn't likng the oil pressure when warm(about 10psi at idle in gear after a pass). When I put it all together, the top of the band was pretty close to the top of the lifter bore at full lift in an un-bushed stock block. I figured it was losing oil volume past lifters. I ended up dropping a steel dowel down the passenger side sending unit hole at back of block to limit oil to drivers side lifters. This brought oil pressure back to a comfortable range. FWIW Here's a link to another members thread with similar issues and posted some pics of what I did.
https://board.moparts.org/ubbthreads/show...rue#Post8241605
Also, for what it's worth, the 87019s are Not pushrod oiling but do have the small edm? hole at bottom of the band.
Re: Updates on the Edelbrock Victor Installed Height Saga [Re: MoParFish] #1753592
02/16/15 03:38 AM
02/16/15 03:38 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
So oil bypassing the lifter, I see.
I have been using the standard solid body roller lifters and an intake pushrod that is 0.025" longer than the exhaust pushrod.
Page 2 of 4 1 2 3 4
