Re: Engine build Dilema... Which way to go????
[Re: DemonDust]
#1753401
02/13/15 12:58 AM
02/13/15 12:58 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Jesse give Diamond a call to. You can send them the old piston get the bore honed to clean it up and order a set with the .043x.043x3mm ring package.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: DemonDust]
#1753402
02/13/15 02:11 AM
02/13/15 02:11 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Pardon my ignorance, but wouldn't you have to bore the cylinders to get them straight? Or can a hone do that too?
Also if I go to whatever bore cleans up straight, is there a on the shelf ring size close to this bore that won't cost an arm and leg?
I'm not trying to be cheap, I have a lot of upgrades planned this winter and don't want to fall on unexpected costs.
You obviously don't bore to final size..........you hone it, so YES, a hone will fix your problem. Too many people think that when a motor gets worn, you must "bore" it to .010, .020, .030, whatever over. NOT true. You hone the motor to the minimum size that gets all the cylinders to SAME size and straight. THEN you order pistons to whatever that bore size is. So lets say your block is clean and straight at 4.186, that's the size you order pistons for and the piston maker will set the clearance in the piston. So what about rings for an odd bore? No problem there either. Rings are "file fit", so you simply order a set of 4.185 bore rings, just like you did before, only you file them less. Its really THAT simple. Again, many are under the assumption that rings are specific for EVERY bore size made. No sir......a ring set of a certain size can be used in MANY bore sizes
Monte
[Re: MR_P_BODY]
#1753403
02/13/15 02:20 AM
02/13/15 02:20 AM
Monte_Smith
North Alabama
Well $1000 for rings is not anything new. In fact twice that is nothing new. These new tiny little rings get real expensive especially in big bores. I paid $1900 for the rings in the 99 Hemi I ran. Pistons were another $2600 but this is 4.700 bore stuff.
I'm glad for you Al... not me.. I wont spend that kind of money for a set of rings... OR a set of pistons.. and I have bought plenty of custom pistons.... a race set of rings is .043... I dont need the odd ball stuff
Its not so much the size of the ring, as the material. We run .043 top and second rings and a standard 3/16 oil ring. The top ring we use is a $100 a hole and the seconds are $50 a hole, so yep, that's $1200 for the two upper rings, then the oil rings are about $50 for all. Super hi tech N/A stuff can be twice that, regardless of land size.
And we re-ring it about every 50 runs
Monte
[Re: Monte_Smith]
#1753404
02/13/15 02:29 AM
02/13/15 02:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Monte
Monte.. like I said to Al.. I wont spend that kind of money... no need to for the junk I run... and 95% of the guys on here are the same
[Re: DemonDust]
#1753406
02/13/15 09:43 AM
02/13/15 09:43 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I looked at JE and diamonds website. They both say they can turn out custom pistons in about 2 weeks. That's pretty impressive, I figured it would be months that's why I didn't entertain the idea of making new ones. Thanks for the info Monte! I'm sure prices will probably be comparable. JE built the pistons originally so it would be no problem for them. Is diamond a pretty good company? I haven't heard a lot about them.
PM Sent
[Re: DemonDust]
#1753408
02/13/15 02:17 PM
02/13/15 02:17 PM
MR_P_BODY
Yes Diamond is a good company... and they can get them out in ABOUT 2 weeks... I had them build a set of pistons with 2 changes to a shelf piston and I picked them up 3 days later.. the place isnt small and they have plenty of equipment and the people to run them.. plus they were a bit cheaper on prices
[Re: Al_Alguire]
#1753409
02/14/15 02:33 PM
02/14/15 02:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
So Monte and Al maybe you could share with us how much power a $2000 set of rings can give over a $500 set in a typical bracket engine and in an ex-NASCAR engine and a heads up Hemi 99
[Re: HotRodDave]
#1753411
02/14/15 06:53 PM
02/14/15 06:53 PM
Monte_Smith
North Alabama
For the rings we use, the answer is don't know and don't care. We are not concerned about if they make more power. We are concerned about maintaining ring seal in the extremely harsh environment WE use them in, which is a HEAVY nitrous load. You do NOT ring a nitrous motor for max power, you ring it to LIVE. In a motor such as ours, I may use as heavy as a 30lb oil package. Its all about ring seal and materials that can stand the abuse. So what makes our rings expensive is the materials used. We use the "M2" material on the top. While many use a "napier" cut second ring, most are cast. We use a special alloy on our second rings with a "napier" cut
But to answer your question, I will say the $2000 ring set will benefit the average bracket motor NONE. Because frankly, seldom is enough precision and attention to detail, in both parts and techniques, put in that type motor for the rings to be of any benefit. In a Pro-Stock, Comp, or class "record attempt" motor.....yes..........in the average bracket motor.....NO.
Monte
[Re: cesar perez]
#1753415
02/17/15 05:22 AM
02/17/15 05:22 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
its cheaper to buy a new wildcat and have monte put some nitrous
What's a wild cat?
[Re: DemonDust]
#1753416
02/20/15 03:13 AM
02/20/15 03:13 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
What's a wild cat?
It's a Buick. They beat Hemis all the time.
Kevin
[Re: DemonDust]
#1753417
02/20/15 04:11 AM
02/20/15 04:11 AM
Posts: 345 Nebraska
451Cuda
Nebraska
What's a wild cat?
A hellcat that hasn't earned it's horns yet?
