1971 AM/FM Mono Speaker Question #1753182
02/12/15 07:22 PM
02/12/15 07:22 PM
Clancy, Montana
celcius232 Offline OP
Clancy, Montana
Did the optional Motorola AM/FM mono radio in a 71 B-body (in my case a Roadrunner) just have the single front dash speaker or was there also a single rear shelf speaker? Also where can I get a correct impedance (4 ohm?) rear shelf speaker for this radio? Thanks.
Re: 1971 AM/FM Mono Speaker Question [Re: celcius232] #1753183
02/12/15 10:01 PM
02/12/15 10:01 PM
Alabama
BigMoneyLewis Offline
Alabama
The rear speaker was an option so..Single front or single front and single rear with fader switch .
Correct speakers will be 8 ohm .
You can guy correct 8 ohm replacements from turnswitch.com .
A modern 4 ohm speaker will overheat the radios output transformer .
Always stick with the correct 8 ohm speakers on these 60's-early 70's radios .
Greg
gregward@mchsi.com phone 256-852-0955
Re: 1971 AM/FM Mono Speaker Question [Re: BigMoneyLewis] #1753184
02/12/15 10:56 PM
02/12/15 10:56 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
OK...
I got a question for you...
1971 AM/FM stereo, OEM, B-body...
I understand the radio puts out 10 watts...
What's a compatible 'modern' speaker???
Re: 1971 AM/FM Mono Speaker Question [Re: RSNOMO] #1753185
02/12/15 11:20 PM
02/12/15 11:20 PM
Alabama
Alabama
OK...
Their isn't a compatible "modern" speaker because all modern speakers produced now are generally 4 ohm .
Your options are to have your originals re-coned , or buy a reproduction 8 ohm from turnswith.com
They offer just about every speaker size for the 60's-70's muscle car era in the original 8 ohm impedance .
Greg
Re: 1971 AM/FM Mono Speaker Question [Re: BigMoneyLewis] #1753186
02/13/15 10:29 PM
02/13/15 10:29 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Appreciate the info...
