Page 2 of 12 1 2 3 4 11 12
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: Quicktree] #1752327
02/12/15 02:19 PM
02/12/15 02:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I guess that's why all the fast race cars run dana's.
Wait last I checked it was all nine inch rears at the track. There you have it....
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: 1967dartgt] #1752328
02/12/15 03:44 PM
02/12/15 03:44 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
...and SBC's...
But is all seriousness, I will be upgrading my 8 3/4 with a 9" for all the reasons already mentioned
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: OUTLAWD] #1752329
02/12/15 04:50 PM
02/12/15 04:50 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
moore and moore has a new narrowed 9 in with axles and other goodies for sale now,all good stuff.jack is a good guy to deal with too....614-302-5858
SFI 25.5 depends,no leak,even at 213 mph....
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: dakotawilly] #1752330
02/12/15 05:07 PM
02/12/15 05:07 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I think for a 10 or 11 second street/strip car like what you drive (someday... ), it doesn't make a damned bit of difference with respect to ET. Pick one and go with it.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: DusterDave] #1752331
02/12/15 06:21 PM
02/12/15 06:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Question Moparts gearheads, what is the difference in pinion centerlines between 8 3/4, Dana 60 and 9" er's?
Mopar to the bone!!!
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: 72Swinger] #1752332
02/13/15 02:38 AM
02/13/15 02:38 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Are we bracket racers or professional racers. Why do you want to change gear sets. If you run low 8ths or faster run the 9 and keep a wad of money ready. The dana, easy set up for 4 to 8 hundred bucks unless you need new parts.Set the gears up right and make sure its straight and it will last for years with no upkeep and one thing less to worry about.Funny, we go to the track and guys are adjusting valves,charging the battery,changing jets,resetting the bars all kind of stupid stuff,why? Don't make it complicated!
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: Cab_Burge] #1752333
02/13/15 02:49 AM
02/13/15 02:49 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Brad, once you see the pinion support spit out on the starting line from a Ford nine inch rear end you will never think of using a Ford type nine or nine and half inch rearend again
$100 pinion support keeps that from happening
Monte
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: cudaman1969] #1752334
02/13/15 02:51 AM
02/13/15 02:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt call it stupid stuff.. some times I'd spend
a Saturday and a Sunday just testing the 4-link..
that got me down to a 1.19 60'..and take most of a
day just doing jet changes ... I guess you are satisfied
with anything
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: MR_P_BODY] #1752335
02/13/15 12:27 PM
02/13/15 12:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
with anything
1.19 60' on a street/strip car like the OP is asking about?
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: justinp61] #1752336
02/13/15 12:42 PM
02/13/15 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
with anything
No its a race car but the person that I quoted isnt
the OP... all I was trying to state was with testing
you can make the car run better and usually more consistent
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: BradH] #1752337
02/13/15 12:46 PM
02/13/15 12:46 PM
Minn
SportF Offline
SportF  Offline
Minn
If all things were equal between the 9" and Dana 60, the 9" with an aluminum center looks better if nothing else.
I am putting a 9" in a 62 Dodge right now, Yukon center. I have another car with a 9" as well. Lots of good opinions here, but looks can play a part as well.
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: justinp61] #1752338
02/13/15 01:22 PM
02/13/15 01:22 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I wish!
My junk was in the mid 1.4s the last times at the track.
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: cudaman1969] #1752339
02/13/15 01:35 PM
02/13/15 01:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Why would I need a wad of money? A properly set up 9 inch is trouble free.
How would I brace a Dana 60 for radials? You know a radial is a dead hooked tire.
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: 1967dartgt] #1752340
02/13/15 01:45 PM
02/13/15 01:45 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Let's keep on track as I am interested in this also.
9 second car 3000 to 3400 lbs what would be cheaper to buy not build?
S Dana 60 or 9 inch?
Monty mentioned the pinion support for 100.00
Matt
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: MattW] #1752341
02/13/15 01:57 PM
02/13/15 01:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Matt
I built my 9" for the Rampage.. its street/strip..
I have a total of $1100 into it.. that was a complete
new center with a posi(I think its a tru track or
the next step up.. I forget) and new gears and bearings..
$70 for the bearing ends.. I had the 2" X 3" tubing
(back brace) laying around the shop... I also had
all the ladder bar and shock brackets... I did make
the ladder bars and I had all the rod ends.. then
it was my time to shorten it and burn it together..
I had to buy axles and brakes but would have either way
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: MattW] #1752342
02/13/15 02:02 PM
02/13/15 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Matt
After all of these ideas, I think Dr. diff will be sending me a nodular 8 3/4 3rd member and 35 spline axles and run w/it cos I`m not steppin in the 9`s legally anyhow and have no desire to. Back to street racin and makin $$$$....................
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: MattW] #1752343
02/13/15 02:18 PM
02/13/15 02:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Matt
that has been explained many times, depending on how much you can do. there are many cheap parts for the 9 available
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: Quicktree] #1752344
02/13/15 03:38 PM
02/13/15 03:38 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I never have understood the Dana vs. 9" deal. It's like women driving SUV's. 40 years ago there wasn't a women in the United States driving a SUV. Then it became chic and now all women want to drive an SUV. 40 years ago there wasn't a 9" in any Mopar in the US. Now it's like a roller cam or a 400 GPH fuel pump, people feel like they won't be socially accepted if they don't have a 9". What a country. It's a Mopar. Put a Dana in it.
2011 Drag Pak Challenger
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: rickseeman] #1752345
02/13/15 03:58 PM
02/13/15 03:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont understand the relationship of the mopar and
the dana... yes mopar used them.. along with MANY
other companies... dana wasnt a division of Chrysler
it was just a company that Chrysler BOUGHT rear ends
from
Re: Street/strip diff upgrade: D60 vs 9" pros & cons [Re: rickseeman] #1752346
02/13/15 04:19 PM
02/13/15 04:19 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Not agreeing or disagreeing with what someone should run, but its the same deal with a 727 too. Used to be great, now its a POS apparently.
