Re: Line boring costs
[Re: CTD5.9]
#1751074
02/10/15 07:57 PM
02/10/15 07:57 PM
Posts: 75,075 U.S.S.A.
JohnRR
U.S.S.A.
not yet, wanted to make sure the block checked out first. If it won't clean up I don't want to have a set of .030 pistons and a .040 block. I could return the caps and just have studs installed and line honed. I just worry about the potential problems.
Drag motor , or a dual purpose car ? If dual purpose with more time spent on the street studs and a linehone and you'll be fine.
Otherwise return the caps and buy a set sized for an RB and it should cost less.
[Re: CTD5.9]
#1751076
02/10/15 08:30 PM
02/10/15 08:30 PM
dogdays
The B is not anywhere close to 75 lb lighter than an RB. The blocks weigh about the same. 440 crank and rods weigh a little more. Pistons are about the same Heads and exhaust manifolds are the same. Intake manifolds aren't that far apart if you switch to an aluminum one for either motor.
What else is there?
I'd say a mud bogging motor is maybe going to be sitting at full throttle and high rpm for quite a bit longer than a drag motor, it pays to beef up the bottom end.
I was under the impression that most aluminum main caps come in B main size.
R.
[Re: dogdays]
#1751079
02/11/15 12:39 PM
02/11/15 12:39 PM
JohnRR
U.S.S.A.
What else is there?
R.
R.
A 400 might weigh 25 ... maybe 35 ... lbs less , but 75 ??
I can't really say how the alum mains are sized , I bought a set from mancini back in )# , but just shipped them off to Dan C. and he installed them ... but they did go in a 400 block ???
