Injectors for 2006 Cummins #1750912
02/10/15 12:26 PM
02/10/15 12:26 PM
Quantico, VA
ParaFrog88 Offline OP
Quantico, VA
Does anyone have a good place to buy rebuilt injectors for a 2006 Cummins?
Looking on line I see the prices all over the place from $1000.00 to $3500.00
I know you get what you pay for but has anyone delt with a good injector rebuilder?
ABE
1967 Coronet R/T 1970 Coronet R/T 1997 Dakota 2006 Ram 3500 DRW
Re: Injectors for 2006 Cummins [Re: ParaFrog88] #1750913
02/10/15 05:18 PM
02/10/15 05:18 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Reman injectors are pretty much a crapshoot. I have got them from several different sources in the last couple of years. Lately we have been getting them from Injectors direct. I am on set #8 from them and only had 1 problem. One of the injectors had a shorted solenoid. Worked fine for 6 months and went bad. They exchanged it with no issue. They are reasonably priced and seem to be good otherwise. I highly recommend getting a 2 micron fuel filter setup before or when you install new injectors. Clean fuel is the key to making them last.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Injectors for 2006 Cummins [Re: 71yelladustr] #1750914
02/11/15 02:54 AM
02/11/15 02:54 AM
chicago il
I
ides Offline
ides  Offline
I
chicago il
i used midwest fuel injector in chicagoland. had 5 rebuilt,one checked and cleaned it was $1800 with the connectors and gaskets.the one that was just cleaned was dealer installed they got me $1400 for 1 injector. do all 6 at one time and upgrade you fuel filter
Re: Injectors for 2006 Cummins [Re: 71yelladustr] #1750915
02/13/15 11:33 AM
02/13/15 11:33 AM
Quantico, VA
Quantico, VA
Thank you for the information I went with the OEM Mopar Injectors from Injectors Direct.
will post after they get put in and tell you all my results.
Re: Injectors for 2006 Cummins [Re: ParaFrog88] #1750916
02/13/15 04:48 PM
02/13/15 04:48 PM
Missouri U.S.A.
Missouri U.S.A.
10.02@134
Re: Injectors for 2006 Cummins [Re: 71yelladustr] #1750917
02/15/15 04:53 PM
02/15/15 04:53 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought new ones from a place on the Internet not rebuilt and they were way less than Mopar oem. I can look up the place but I see you have already bought. I did the fuel system upgrade with a new pump and micron filters. Skip that and you will be replacing injectors again. That was the big problem with 05 and 06 injectors.
Re: Injectors for 2006 Cummins [Re: fastmark] #1750918
02/15/15 08:21 PM
02/15/15 08:21 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would never buy anything but new injectors
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Injectors for 2006 Cummins [Re: dusturbd340W5] #1750919
02/18/15 11:41 PM
02/18/15 11:41 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My new ones cost me only $340 each. I bought all six.
Re: Injectors for 2006 Cummins [Re: fastmark] #1750920
02/19/15 02:08 PM
02/19/15 02:08 PM
Quantico, VA
Quantico, VA
Don't know if I did good or bad but the set of 6 OEM Reman injectors was $1500.00 and the labor for instal was $700.00. Havent put any real miles on it since I just picked it up.
Mechanic said water in the fuel was the most likely down fall plus 400,000 miles on the truck. Not the orignal owner so don't know if they were changed before.
I put 10,000 miles on it in the previous month.
Re: Injectors for 2006 Cummins [Re: ParaFrog88] #1750921
02/19/15 04:55 PM
02/19/15 04:55 PM
Missouri U.S.A.
Missouri U.S.A.
The install price was a little steep IMHO.
10.02@134
Re: Injectors for 2006 Cummins [Re: 71yelladustr] #1750922
02/19/15 05:18 PM
02/19/15 05:18 PM
Quantico, VA
Quantico, VA
Labor did seem a bit high but I'm in the Metro Washington DC area. The shop all ready had the truck. So kind of over a barrel.I'm originaly from Iowa and my wife is from Kentucky so labor costs are a lot less out that way.
