Re: What brand adhesive sticks to plastic door panels?
[Re: Bigfury]
#1750904
02/10/15 12:15 PM
02/10/15 12:15 PM
Posts: 952 Queens, N. Y.
FASTBACK340
Queens, N. Y.
I would give the plastic a good wiping-down with alcohol and let it air-dry. A good spray adhesive should do the job (3M upholstery adhesive comes to mind….) just don't soak it on. Spray a light coating to both the panel AND the backside of the material. Allow it to set up for a minute, and CAREFULLY apply using a soft squeegee to get the air & wrinkles out. Go slow and practice with scrap to get a feel for how the material will stretch and apply.
`68 Barracuda 340-S
[Re: Bigfury]
#1750905
02/10/15 01:30 PM
02/10/15 01:30 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have not found anything that will stick long term. The originals were made of polypropylene and are highly resistant to solvents and glues. From Wikipedia:
Many objects are made with polypropylene precisely because it is resilient and resistant to most solvents and glues. Also, there are very few glues available specifically for gluing PP. However, solid PP objects not subject to undue flexing can be satisfactorily joined with a two part epoxy glue or using hot-glue guns. Preparation is important and it is often helpful to roughen the surface with a file, emery paper or other abrasive material to provide better anchorage for the glue. Also it is recommended to clean with mineral spirits or similar alcohol prior to gluing to remove any oils or other contamination. Some experimentation may be required. There are also some industrial glues available for PP, but these can be difficult to find, especially in a retail store.
Good luck, Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
