headers on stock 440 ??? #175080
12/25/08 11:35 PM
12/25/08 11:35 PM
CT USA
N
Nick Mineau Offline OP
N
CT USA
im shure its been asked before but how many ponies are a set of headers worth on a 1966 440 with non hp manifolds, ch4b intake ande 260/272 cam. just wndering if i would see any improvemt.
merry xmas
Re: headers on stock 440 ??? [Re: Nick Mineau] #175081
12/25/08 11:40 PM
12/25/08 11:40 PM
MO
cdp Offline
cdp  Offline
MO
seems the going rate is 15-25 ponies.
Re: headers on stock 440 ??? [Re: cdp] #175082
12/26/08 12:09 PM
12/26/08 12:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yes you will see a gain in HP amd MPG.
Re: headers on stock 440 ??? [Re: Mr.Yuck] #175083
12/26/08 12:24 PM
12/26/08 12:24 PM
My 440 was had a true 9.5:1 CR and was rated at 350 HP.
With nothing more than a mild cam and set of small headers it was putting out an easy 400 according to my dragstrip times.
Stock intake, heads, valves, bore, pistons, etc.
Re: headers on stock 440 ??? #175084
12/26/08 05:06 PM
12/26/08 05:06 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Yes the cheap headers with a true 2.5" dual exhaust and cheapie turbo mufflers should be the standard for a decent 440 engine. If you have the money than by all means check into Thorley or TTI but the $129 summit cheapos will be fine.
Keep old mopars alive.
Re: headers on stock 440 ??? [Re: 2boltmain] #175085
12/26/08 05:54 PM
12/26/08 05:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I got the summit headers and their 3" kit for under $350 total. TTi's are nice but not worth the price. You can use your exhaust mani studs w/ the summits too.
Re: headers on stock 440 ??? [Re: Mr.Yuck] #175086
12/26/08 07:09 PM
12/26/08 07:09 PM
Summit was out of their house brand for weeks a few years back. They subbed Walker Dynomax headers and they fit/worked REALLY well. I was impressed with the quality, fit and the way the tucked up under the car.
Re: headers on stock 440 ??? #175087
12/26/08 08:16 PM
12/26/08 08:16 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Shhh! Dont say TTIs are expensive. Other members will flame you calling you poor and unfit to own a mopar for not being able to cough up $800.
Re: headers on stock 440 ??? [Re: 2boltmain] #175088
12/26/08 08:20 PM
12/26/08 08:20 PM
Kirkland, Washington
Pacnorthcuda Offline
TTI's are overpriced. I'll take a $170 set of Hedmans with $300 of Jet-Hot ceramic coating anyday.
NEVER had a leak with hedmans in 16 years of 440 e-body applications.
Re: headers on stock 440 ??? [Re: Nick Mineau] #175089
12/26/08 09:49 PM
12/26/08 09:49 PM
Central NC
gch Offline
gch  Offline
Central NC
You can usually find a set of used headers reasonable.I have picked up a couple sets of 1 7/8 hookers in decent shape.
For a stock/mild motor the cheapo 1 3/4 will work fine and be an improvement over manifolds with a good 2.5 exhaust system and some decent flowing mufflers.You may need to rejet the carb a little richer to see all of the gains.
Re: headers on stock 440 ??? [Re: 2boltmain] #175090
12/26/08 11:50 PM
12/26/08 11:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I know! OVER-RATED. I too have used every el-cheapo brand under the sun and have never had a fit/leak/clearence issue. TTI no doubt makes nice stuff but I have heard just as many horror stories as I have good. And my buddy had several issues w/ a 2.5 system he put on a 4 speed RR. For the cash they charge the stuff should jump out of the box and install itself.
Re: headers on stock 440 ??? [Re: Mr.Yuck] #175091
12/27/08 12:53 PM
12/27/08 12:53 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Big block mopar dudes have an advantage over small block mopar dudes. In the small block world we all want headers that DO NOT run any of the tubes way under the car. (ground clearnce issues!) So in order to get the headers that dont do this you must step up to Thorleys, Dougs or TTI. All expensive (TTI being ridiculous) With big blocks even the $99 headers route the tubes allowing ground clearance. What if an offshore manufacturer were to make a "SIMILAR" header to TTI for like $200.................
Re: headers on stock 440 ??? [Re: 2boltmain] #175092
12/27/08 01:18 PM
12/27/08 01:18 PM
We couldn't get that lucky & if we did someone wouldn't use them because they are "offshore"
Re: headers on stock 440 ??? [Re: RapidRobert] #175093
12/30/08 01:55 AM
12/30/08 01:55 AM
CT USA
N
N
CT USA
thanks for the info. looks like its a worthwhile investment to get some more hp
