What trans? 97 3.9 Dakota 5 spd? #1750266
02/09/15 08:30 PM
02/09/15 08:30 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Didn't dodge switch to the NV 3500 behind the 3.9 in the Dakota? Found a 2wd 97 v-6 5 speed. I want to put the trans behind a LA small block, 318 or 360, in a 46 dodge 1/2 ton.
How can your average junk yard scrounger tell the difference between the ax15 and the nv 3500?
Re: What trans? 97 3.9 Dakota 5 spd? [Re: Lmopar69] #1750267
02/09/15 09:36 PM
02/09/15 09:36 PM
scratchnfotraction Offline
ax15 has removable bell housing = 9 bolts in a horseshoe shape around front input bearing on the inside of bell.
nv3500 bell is intergraded into the main case/body. the main case is 2 piece with a front back 1/2.
nv3500 is bigger next to ax15
Re: What trans? 97 3.9 Dakota 5 spd? [Re: scratchnfotraction] #1750268
02/09/15 10:45 PM
02/09/15 10:45 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Roger that. I think I'll go get the trans. If memory serves, I'm pretty sure it's an nv 3500. Should handle a mild small block in a driver.
Thanks.
Re: What trans? 97 3.9 Dakota 5 spd? [Re: Lmopar69] #1750269
02/10/15 01:04 AM
02/10/15 01:04 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think only the 4x4s got the ax-15.
Re: What trans? 97 3.9 Dakota 5 spd? [Re: DaytonaTurbo] #1750270
02/10/15 01:06 AM
02/10/15 01:06 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My 98 3.9 2wd had the AX
Around 2000? 2001? All 3.9s had the NV3500. Dodge probably realized it was cheaper to buy twice as many of 1 Trans and made the switch
**Photobucket sucks**
