Best tool for removing terminals from wiring harness? #1749891
02/09/15 02:23 AM
02/09/15 02:23 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
I need to remove the connector from my dome light wiring harness so I can pull the wiring up through the A-pillar.
I seem to remember somebody made a nice set of tools specifically for pulling the terminals out of Mopar harnesses... but for the life of me can't find it now.
In additional to removing the dome light harness, I have a pile of old wiring from both of my cars I like to snag the good connectors off of for spares, custom harness additions, etc.
I found a couple kits for sale online but they are designed to take apart pretty much every design of connector ever made... and usually find that tools intended to everything don't do one specific thing very well....
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Best tool for removing terminals from wiring harness? [Re: Slant6pak] #1749892
02/09/15 02:31 AM
02/09/15 02:31 AM
for the firewall bulkhead, the male terminals: one leg is unsupported but you cannot (easily) tell which one it is when they are installed so press each side & the one that moves, press it closer to the other leg untill the pigtail will easily pull out the back side. the female connectors, there is a mini slot on one side of the bulkhead rectangle the terminal is in & stick an eyeglass screwdriver in & flatten the tab flush with the terminal (you cant see it) & move the screwdriver in parallel as opposed to angle leveraging it and when it is flat you can easily pull the pigtail out the back. Dont force either by pulling hard, just work the terminal some more. If your connectors are the same as these then there ya go.
Re: Best tool for removing terminals from wiring harness? [Re: RapidRobert] #1749893
02/09/15 03:56 AM
02/09/15 03:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
usually dome light connectors going through A pillars use this plug ( not the packards 56 kind ):
so I guess you can get:
http://www.princessauto.com/en/detail/2-pc-automotive-terminal-removal-tool-set/A-p8006462e
although I'm really drastic and use plat precision screw drivers for everything LOL... including those rounded ones which gets two tabs. Of course after make that, needs to get it back to shape LOL.
BUT harness can be pulled out from A pillar without need to remove the plug... diff stuff is reinstall it
Re: Best tool for removing terminals from wiring harness? [Re: NachoRT74] #1749894
02/09/15 01:11 PM
02/09/15 01:11 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Magnifying glasses
Re: Best tool for removing terminals from wiring harness? [Re: Slant6pak] #1749895
02/09/15 01:35 PM
02/09/15 01:35 PM
NC
1970A66 Offline
1970A66  Offline
NC
The "best" option is to buy the proper diameter pin extractor such as this: http://www.ebay.com/itm/4-Pin-Molex-Powe...=item4adf0844b2
(Note: I'm not saying the above is your correct extractor)
Another option is to fabricate your own using the sections from a telescoping magnetic or antenna: http://www.ebay.com/itm/Portable-Telesco...=item5d53c318a0
Use a tubing cutter, separate each section then slip the best fitting one around your pin and wiggle. It works well. You can ream/enlarge the ID as necessary for your pin diameter. Go fancy by installing a wood ball from a hobby store on the opposite end to protect your hand.
Re: Best tool for removing terminals from wiring harness? [Re: 71GTX471] #1749896
02/09/15 02:30 PM
02/09/15 02:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Magnifying glasses
LOL, sorry, was the only pic I found on the web to show the plug on this assembly LOL
coming back to topic... I posted a nice tool for that. Just that the giant pic makes the link small LOL
Re: Best tool for removing terminals from wiring harness? [Re: Slant6pak] #1749897
02/09/15 08:25 PM
02/09/15 08:25 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Any idea why text in your posting,,,and that of respondents is such a small font? I see this on some postings and have not figured how or why this happens.
Old eyes want to know.
Re: Best tool for removing terminals from wiring harness? [Re: NachoRT74] #1749898
02/09/15 11:48 PM
02/09/15 11:48 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Magnifying glasses
I have a tool like this and it is awesome. I use a set of roll pin needle nose pliers for the male end at the bulkhead connector.
Careful, your character's showing!
Re: Best tool for removing terminals from wiring harness? [Re: Sxrxrnr] #1749899
02/10/15 02:04 AM
02/10/15 02:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Because the first photo is so big, the page needed to go wider. But the font stays the same on the bigger page as it is on a regular page. Then if your display shows the page at full width, the font gets squshed. That's my theory, and I'm sticking to it.
Re: Best tool for removing terminals from wiring harness? [Re: kentj340] #1749900
02/10/15 10:19 AM
02/10/15 10:19 AM
London, England
Gavin Offline
Gavin  Offline
London, England
If you are cheap or short of time, you can make your own from a short length of brake pipe! I did this for my bulkhead connector terminals. Cut a length, put it in a drill chuck, and then sand or file the outside diameter until the wall thickness is thin (that's a technical term - 'thin' ).
Quick and easy. If you have a bunch to do, I'd buy the tool....
Re: Best tool for removing terminals from wiring harness? [Re: Gavin] #1749901
02/10/15 12:23 PM
02/10/15 12:23 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Along these lines of quick, expendable, and cheap….
I use the old metal tension-strips that come on wiper blades. Cut into short lengths and hit the edges on a grinding wheel. Thin it out (there's that technical term again…) so it fits into the terminal end your working on. I made a selection of about 1/2 dozen with a piece of bright yellow shrink wrap on the tips. If I don't see it and loose it, no big deal. Just make more from scrap. I make them long, short, I even bend the ends for leverage.
BUT….. these only work on flat terminals. The above tip covers round pins. I guess we covered it all, no?
`68 Barracuda 340-S
Re: Best tool for removing terminals from wiring harness? [Re: FASTBACK340] #1749902
02/10/15 02:13 PM
02/10/15 02:13 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Nothing wrong with homemade tools. Sometimes I value my time more though.
These in various thicknesses will cover 95% of everything thats not molex or molex like.
http://www.delcity.net/store/Metri-Pack-...CFRckgQodM1IAew
Molex in different sizes also
http://www.alliedelec.com/molex-incorpor...CFUk8gQodnDIAoA
Re: Best tool for removing terminals from wiring harness? [Re: kentj340] #1749903
02/10/15 02:57 PM
02/10/15 02:57 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Guess I won't be reading on my IPhone. Thanks for your insight.
Re: Best tool for removing terminals from wiring harness? [Re: 135sohc] #1749904
02/10/15 03:22 PM
02/10/15 03:22 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Interesting. Any idea the size needed for our Chrysler bulkhead connectors?
1968 Plymouth Road Runner 383 4 speed
Re: Best tool for removing terminals from wiring harness? [Re: dobie] #1749905
02/10/15 05:09 PM
02/10/15 05:09 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
http://www.clipsandfasteners.com/Terminal_Extractor_Pick_Wide_Blade_090_p/a14885.htm
I have that one and the smallest one
http://www.clipsandfasteners.com/Micro_Terminal_Extractor_Pick_035_Blade_p/a20583.htm
There are more sizes I know of but cannot find them right now. AUVECO sells 3-4 different sizes. The .090 should be plenty big enough for the bulk head connector.
Re: Best tool for removing terminals from wiring harness? [Re: 135sohc] #1749906
02/10/15 06:10 PM
02/10/15 06:10 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Thank you! I've fought with tiny screwdrivers enough to know that a proper tool is money well spent.
Re: Best tool for removing terminals from wiring harness? [Re: NachoRT74] #1749907
02/10/15 07:33 PM
02/10/15 07:33 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Smart move is to attach a messenger line to it when removing, to be used for pulling it back in.
Re: Best tool for removing terminals from wiring harness? [Re: Vert] #1749908
02/10/15 11:11 PM
02/10/15 11:11 PM
Houston, Texas
Houston, Texas
Yes that is....
Too bad I'm pulling it out of one car to put in another
Thank you for all the replies guys. I'll check out all of the links provided. I had already found the extractors that are round... but it looks like a great way to stab yourself in the hand with the bit you aren't using
Re: Best tool for removing terminals from wiring harness? [Re: Vert] #1749909
02/12/15 01:58 AM
02/12/15 01:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yes it is, but can be used a hard wire too throught the pillar if you didn't do it
Re: Best tool for removing terminals from wiring harness? [Re: mopar346] #1749910
02/14/15 06:11 PM
02/14/15 06:11 PM
None
71rm23 Offline
71rm23  Offline
None
Magnifying glasses
Where can I get some of them from?
