Re: Two piece spindles???!!!
[Re: DieselDart73]
#1749064
02/08/15 02:40 PM
02/08/15 02:40 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Your drum knuckles should basically look identical to this Are the 5/8 bolts you are talking about the ones that hook to the lower ball joint? Sounds like it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: MuuMuu101]
#1749066
02/08/15 02:47 PM
02/08/15 02:47 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Chevy and Ford guys call them "2 piece" because the lower BJ bolts to them. Drum spindles are pretty close through the years but 72 and down had smaller bearings on A-bodies and the 9" drum spindles used smaller bolts to hold the lower bj than 10" did IIRC.
Mopar to the bone!!!
[Re: 72Swinger]
#1749067
02/08/15 02:50 PM
02/08/15 02:50 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
That explains it.
[Re: DieselDart73]
#1749069
02/08/15 02:52 PM
02/08/15 02:52 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So if I get 72 spindles they'll bolt right up in there? I really don't want to have to get another kit would like to make this one work.
Post the kit number.
[Re: DieselDart73]
#1749074
02/08/15 03:13 PM
02/08/15 03:13 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Sorry it's 140-2723-b
It still uses the same spindle as mentioned above.
[Re: DieselDart73]
#1749076
02/08/15 03:22 PM
02/08/15 03:22 PM
72Swinger
Nebraska
72 and older 10" drum spindles.
