Re: 5.7 Hemi in a 67 Barracuda
[Re: Daty Rogers]
#17468
11/14/05 03:36 PM
11/14/05 03:36 PM
I've been following this thread, but I've tried bolting up a bellhousing off a smallblock la to the back of the 5.7l hemi. It seems as though one of the bolt holes doesn't want to line up (just misses by about .040). Has someone actually bolted up an la bellhousing to the new hemi and everything lines up perfect, including any runout issues?
[Re: Daty Rogers]
#17471
11/16/05 11:09 AM
11/16/05 11:09 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
The throttle cable/kickdown has been solved, Bouchillon Performance has a throttle bracket and kickdown cable the will fit perfectly and still use the slanty throttle cable. He's going to test it on one of his 5.7s in the back before he ships but looking at the part there won't be any problem. http://www.bouchillonperformance.com/BPEtkdc.aspIt's looking better and better! -Daty
[Re: Daty Rogers]
#17473
11/19/05 04:42 PM
11/19/05 04:42 PM
Posts: 1,106 michigan
440whiteboy
michigan
hey daty -- can you post a overall pic and of the connection lines
They only see Stars... when hit by a Mopar!
[Re: Daty Rogers]
#17475
11/21/05 01:40 AM
11/21/05 01:40 AM
Posts: 4,442 Texas
Daty Rogers
Texas
[Re: 57HemiDart]
#17480
11/27/05 11:53 PM
11/27/05 11:53 PM
440whiteboy
michigan
Hey Daty just got my tank in from Don and its just like yours -- no other parts in yet.
Finally got my block off plate from TTI and installed that. Also got the motor mounts from TTI and Remounted the motor. Had to grind the passenger side motor mount corner to fit.
One note about the S & P motor mounts are they seems a bit more sturdy than the TTI set with more mounting bolts. Also they measure the same so the motor still would sit in the same location. Only thing I can see is that TTI's set are offset on an downward and to the side angle -- so that might be for the Headers to clear ?
This pic is of my installed motor -- passenger side from the rear looking forward -- so far seems like I have good clearance -- still will have to fit the Headers from TTI.
I have pre-fit the bell housing --its hard to tell about the trans for the motor is tilting back untill the trans and mount are installed I wont know without cutting the hump to fit in talking to Keislers staff..
my next step is waiting to get more time to then cut the hump out and to pre-fit the Trans.
[Re: 440whiteboy]
#17481
11/28/05 12:04 AM
11/28/05 12:04 AM
440whiteboy
michigan
This pic is from the rear of the Drivers side looking forward. At the moment I have the power steering gear box in. Have not tried the Headers yet to find out if that has to go or not? The oil pan fits in nicely with the steering linkage.
[Re: Daty Rogers]
#17485
11/28/05 11:23 AM
11/28/05 11:23 AM
440whiteboy
michigan
Yes the the vent bung is on the passenger side. If its next to the rail can you use a hole cutter to bore thur both sides of the rail? Thats the way the vent tube is done.
My tank is not installed yet. I wont do the tank untill I get my rear end axle changed first.
Does a sending come with this package from Don?
