Quad headlights, but Low Beams only work on High?? #1747338
02/05/15 05:11 PM
02/05/15 05:11 PM
Somewhere near Palm Springs
ConvertiBee Offline OP
On my '71 Cuda, the Low beams will not come on by themselves... ala carte. They DO come on when I also turn on the High beams...all 4 headlights do. At 1st I thought this would be a faulty floor switch, but I removed the switch and test-jumpered from the "Hot" wire that feeds the switch, and then into the Violet wire leading out, which the wiring diagram shows as going directly to the Low Beam side of the headlights.
Nothing!
What am I missing here? They've never worked since I bought this car a couple of years ago... I don't drive at night, but I WOULD like to get this fixed!
Thanks for your help in advance
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: Quad headlights, but Low Beams only work on High?? [Re: ConvertiBee] #1747339
02/05/15 05:50 PM
02/05/15 05:50 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You do realize that on low beam there are only the 2 outside sealed beams that come on. The inner 2 sealed beams only have one element and it is wired to the high beam side.
Re: Quad headlights, but Low Beams only work on High?? [Re: MoparforLife] #1747340
02/05/15 06:28 PM
02/05/15 06:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To clarify the "low beam" headlights have both low and high beam filaments in them. Odds are your low beams are not coming on at all and you are seeing the highs in all four headlights.
I would look at your floor dimmer as that is where the switch is made and they do have a tendency to go bad being where the muck and wet is.
Don't be the exception.
Re: Quad headlights, but Low Beams only work on High?? [Re: Supercuda] #1747341
02/05/15 07:01 PM
02/05/15 07:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Are you sure the low side of the bulbs are good?Ive seen them burn out and the high side still is good.Time for a wiring diagram and test light if the bulbs are good on both low filaments.The inner highs only have 1 filiment thats why the lows have 3 pins and highs 2 pins.Rocky
Chrysler Firepower
Re: Quad headlights, but Low Beams only work on High?? [Re: therocks] #1747342
02/05/15 07:35 PM
02/05/15 07:35 PM
(1) push the dimmer switch to "low beam" & pull the connector off & see if the specific switch terminal is hot (2) if not clean or replace the switch (3) if its hot plug the connector back in & pull the connectors off of the low beam lights and see if the specific female connector terminal (the one from switch low beam terminal) behind each light is hot. (4) if not there is an open rearward to the dimmer switch (check bulkhead first) (4) if both are hot then ohm the male terminals on the low beam headlights to check for an open. I'm thinking there is 1 ground for each side of the vehicle (1 low beam/1 high beam), it's been awhile & it must already have continuity to ground as you are getting some filaments lit up but do some checking & holler back. EDIT the violet with tracer wire is the low beam circuit (1) see if it is hot at both low beam lights (dimmer on low) (2) if so pull the connector off of each low beam bulb and ground the bulb male lug the black wire connector was on & (3) jump fire to the high side (other end "red wire" male lug) & see if it lights up and (4) Then jump fire to the low side (middle male lug that the violet wire was on) & see if it light up (check both low beam bulbs) & not likely both lights went bad so see what develops
Re: Quad headlights, but Low Beams only work on High?? [Re: RapidRobert] #1747343
02/05/15 07:59 PM
02/05/15 07:59 PM
Upper Midwest
Upper Midwest
I neglected to say in my first post that on high beam all 4 head lights should come on.
Re: Quad headlights, but Low Beams only work on High?? [Re: RapidRobert] #1747344
02/06/15 03:12 PM
02/06/15 03:12 PM
Thank you all, especially RapidRobert! I got it fixed... it was a little bit of everything: 1 bad bulb, a sticky switch, a crappy ground.
It's all working 100% now Thanks!!
'72 Cuda 340 FE5
