1958 Savoy V8 Conversion??? #1747320
02/05/15 02:27 PM
02/05/15 02:27 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
I'm currently contemplating doing a V8 conversion in a 1958 Savoy 4 door 6cyl 3 on the tree. Thinking of going with a carbuerated small block 318, 340 or 360 and a 904 or 727 trans. What will I need as far as mounts, exhaust and radiator. are there any kits available? Also whats available as far as front disc brake conversions?
Re: 1958 Savoy V8 Conversion??? [Re: vttm] #1747321
02/05/15 02:41 PM
02/05/15 02:41 PM
jersey
Spaceman Spiff Offline
jersey
www.forwardlook.net
Ask around here.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 1958 Savoy V8 Conversion??? [Re: vttm] #1747322
02/05/15 03:05 PM
02/05/15 03:05 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
When I had my 57 Dodge, I knew you could buy a conversion kit, but later also found out that you can get the setup from any Dip/Leb/Gen2 Doba discbrake setup, and it's all Mopar. But I also know if you can get disc setup from a late B those work as well. This is what I was told, so I've not actually done the job
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
