S.B. Indy heads #1747197
02/05/15 12:15 PM
02/05/15 12:15 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Where to buy? I'm considering stepping up from my Edelbrocks on my street/strip 408. Most likely 360-1, I'd like to buy them ported with rockers, bolts and intake. Who do you guys use and why?
Re: S.B. Indy heads [Re: justinp61] #1747198
02/05/15 01:08 PM
02/05/15 01:08 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Brian @ IMM engines.com.
Re: S.B. Indy heads [Re: justinp61] #1747199
02/05/15 01:14 PM
02/05/15 01:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From where your located.. call Bob George in PA.. he
is a Indy dealer
Re: S.B. Indy heads [Re: justinp61] #1747200
02/05/15 01:53 PM
02/05/15 01:53 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
DO NOT buy from Indy directly.
Get them bare through a Dealer and have them assemble and PRESSURE check?
Money well spent.
Good product but lousy service.
Matt
Re: S.B. Indy heads [Re: MattW] #1747201
02/05/15 04:01 PM
02/05/15 04:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Money well spent.
Matt
Maybe it's just me but it don't sound like a good product if a brand new one needs pressure checked I do hear that a lot about their products though
Re: S.B. Indy heads [Re: HotRodDave] #1747202
02/05/15 04:37 PM
02/05/15 04:37 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Money well spent.
Matt
Good product as in they make power.
Quality control is another thing
Don't as me how I know
Re: S.B. Indy heads [Re: MattW] #1747203
02/05/15 05:30 PM
02/05/15 05:30 PM
W. Kentucky
W. Kentucky
The quality scares me, maybe I'll wait and see if Edelbrock actually makes their new head. The only thing about the Edelbrocks is that I may be to old to mess with them when they come out.
Re: S.B. Indy heads [Re: justinp61] #1747204
02/05/15 05:38 PM
02/05/15 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO.. but if you go through a dealer I believe you
will have way less of a issue.. you can return them
to the dealer and let him deal with Indy IF there is
any issue... again.... JMO call Bob George and ask...
OR call Shady Dell Speed Shop and ask Ryan.. I dont
know why he no longer post here.. but he might be
one of my choices to port them being its in your hood
Re: S.B. Indy heads [Re: MR_P_BODY] #1747205
02/05/15 06:21 PM
02/05/15 06:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I inquired about going the Indy route after my W5 liquidation..... got a lot of similar stories of sub par castings, and water where it shouldn't be. Wasn't at all interested in the possibilty of reliving that experience. I patiently waited for the "new" Edelbrocks to rise from the dust......that was 2012. Good luck!
Re: S.B. Indy heads [Re: J_BODY] #1747206
02/05/15 06:52 PM
02/05/15 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've bought 1 item produced by Indy.. that was my one
intakes(W-2) and it works very well...didnt leak any
water.. LOL
Re: S.B. Indy heads [Re: MR_P_BODY] #1747207
02/05/15 08:07 PM
02/05/15 08:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have an early set and a later set. both fully ported. no problems with water but I did have to tube the head bolt holes on the set that's max ported.
Re: S.B. Indy heads [Re: Quicktree] #1747208
02/05/15 08:34 PM
02/05/15 08:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
who the heck is this Max Ported guy I keep hearing about?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: S.B. Indy heads [Re: pittsburghracer] #1747209
02/05/15 08:45 PM
02/05/15 08:45 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what? not a guy-maximum port work meaning it's hogged out
Re: S.B. Indy heads [Re: Quicktree] #1747210
02/05/15 10:46 PM
02/05/15 10:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Stage V porting..... the one before Stage whoops!
Re: S.B. Indy heads [Re: J_BODY] #1747211
02/05/15 11:50 PM
02/05/15 11:50 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Re: S.B. Indy heads [Re: tubtar] #1747212
02/06/15 12:03 AM
02/06/15 12:03 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
AGREED! good power making head HORRIBLE! customer service, has a 50% chance of showers LOL!
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: S.B. Indy heads [Re: J_BODY] #1747213
02/06/15 12:04 AM
02/06/15 12:04 AM
slammedR/T Offline
slammedR/T  Offline
racemagnum
Re: S.B. Indy heads [Re: justinp61] #1747214
02/06/15 12:28 AM
02/06/15 12:28 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Try the Indy 360-2's that is what I am running ported by Brett Miller and they flow 337 @.650
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: S.B. Indy heads [Re: D-50] #1747215
02/06/15 06:39 AM
02/06/15 06:39 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
save your money stick with what you have and if you need more power gas it ,you are only getting around 28 cfm more with them and there rockers springs are junk and you will need a bigger cam and more comp to see the power impove it a bit and xross your legs they do not leak
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: S.B. Indy heads [Re: Ian] #1747216
02/06/15 08:42 AM
02/06/15 08:42 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
most of the problems were with the older heads and most with the cnc 245 deal. I have seen eddies heads leak too.
