Re: S.B. Indy heads
[Re: justinp61]
#1747200
02/05/15 01:53 PM
02/05/15 01:53 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Where to buy? I'm considering stepping up from my Edelbrocks on my street/strip 408. Most likely 360-1, I'd like to buy them ported with rockers, bolts and intake. Who do you guys use and why?
DO NOT buy from Indy directly. Get them bare through a Dealer and have them assemble and PRESSURE check? Money well spent. Good product but lousy service. Matt
Re: S.B. Indy heads
[Re: HotRodDave]
#1747202
02/05/15 04:37 PM
02/05/15 04:37 PM
MattW
Ontario Canada
Maybe it's just me but it don't sound like a good product if a brand new one needs pressure checked I do hear that a lot about their products though
Good product as in they make power.
Quality control is another thing
Don't as me how I know
Re: S.B. Indy heads
[Re: justinp61]
#1747204
02/05/15 05:38 PM
02/05/15 05:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The quality scares me, maybe I'll wait and see if Edelbrock actually makes their new head. The only thing about the Edelbrocks is that I may be to old to mess with them when they come out.
JMO.. but if you go through a dealer I believe you will have way less of a issue.. you can return them to the dealer and let him deal with Indy IF there is any issue... again.... JMO call Bob George and ask... OR call Shady Dell Speed Shop and ask Ryan.. I dont know why he no longer post here.. but he might be one of my choices to port them being its in your hood
Re: S.B. Indy heads
[Re: J_BODY]
#1747206
02/05/15 06:52 PM
02/05/15 06:52 PM
MR_P_BODY
I inquired about going the Indy route after my W5 liquidation..... got a lot of similar stories of sub par castings, and water where it shouldn't be. Wasn't at all interested in the possibilty of reliving that experience. I patiently waited for the "new" Edelbrocks to rise from the dust......that was 2012. Good luck!
I've bought 1 item produced by Indy.. that was my one intakes(W-2) and it works very well...didnt leak any water.. LOL
Re: S.B. Indy heads
[Re: pittsburghracer]
#1747209
02/05/15 08:45 PM
02/05/15 08:45 PM
Quicktree
I have an early set and a later set. both fully ported. no problems with water but I did have to tube the head bolt holes on the set that's max ported.
who the heck is this Max Ported guy I keep hearing about?
what? not a guy-maximum port work meaning it's hogged out
Re: S.B. Indy heads
[Re: J_BODY]
#1747213
02/06/15 12:04 AM
02/06/15 12:04 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Stage V porting..... the one before Stage whoops!
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: S.B. Indy heads
[Re: justinp61]
#1747214
02/06/15 12:28 AM
02/06/15 12:28 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Try the Indy 360-2's that is what I am running ported by Brett Miller and they flow 337 @.650
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
