Would you trust old synthetic gear oil? #1746670
02/04/15 09:06 PM
02/04/15 09:06 PM
Fallon, Nv
SeventyGTX Offline OP
Fallon, Nv
I'm doing a gear swap in my 05 Jeep Liberty and it calls for 75w90 synthetic in the rear. I have had two quarts of Redline on the shelf for years, in fact the sticker on it says 2002.
The caps have never been removed, so they have been sealed all these years. Should I worry about pouring this stuff in a new gear set and Detroit Tru-trac?
Re: Would you trust old synthetic gear oil? [Re: SeventyGTX] #1746671
02/04/15 09:09 PM
02/04/15 09:09 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I'd use it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Would you trust old synthetic gear oil? [Re: HemiRick] #1746672
02/04/15 11:01 PM
02/04/15 11:01 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Use it, from what i read, as it gets older it goes to the higher viscosity, reg oil the opposite. Not sure what synthetic oils eventually brake down to but reg. oil remains oil indefinitely just gets dirty and the additives deteriorate. Feel free to correct me if I'm wrong, just what i read.
Re: Would you trust old synthetic gear oil? [Re: SeventyGTX] #1746673
02/05/15 01:06 AM
02/05/15 01:06 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
To be safe, I'd call Redline and see what they recommend for shelf-life. While you have then on the phone, maybe confirm your application as well.
Generally it's the additives falling out of suspension is the concern.
Re: Would you trust old synthetic gear oil? [Re: CompSyn] #1746674
02/05/15 08:12 PM
02/05/15 08:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No need to change synthetic in a vehicle after that amount of time so why would being in a clean sealed container bother it? use it. Or send it to me, I'll use it.
Doug
Re: Would you trust old synthetic gear oil? [Re: dvw] #1746675
02/05/15 08:30 PM
02/05/15 08:30 PM
dogdays Offline
dogdays  Offline
Or me.
R.
Re: Would you trust old synthetic gear oil? [Re: dogdays] #1746676
02/05/15 11:08 PM
02/05/15 11:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm pretty sure most of what it is made out of is north of a million years old already.
Kevin
Re: Would you trust old synthetic gear oil? [Re: SeventyGTX] #1746677
02/05/15 11:15 PM
02/05/15 11:15 PM
"Would you trust old synthetic gear oil"? in a heartbeat
