Re: School me on reverse manual valve bodies for 727's
[Re: moparmanjames]
#1745020
02/02/15 06:18 PM
02/02/15 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I get to the line and let off and the engine braking slows the car down, it would be nice to have no engine braking in 2nd so I could just shift back up to 2nd and coast with the engine idling. Is there a valve body for a 727 that has this feature?
The no LBA VB will do that in low but none I know of will do that in second.. the only other thing would be the clean neutral(after high gear)... but with a manual VB you are in the gear your shifter is in.. as in the shifter is in high.. your in high even standing still ![](/ubbthreads/images/graemlins/wave.gif)
[Re: J_BODY]
#1745024
02/03/15 12:21 AM
02/03/15 12:21 AM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Clean N transbrake. Call Dave, he's doing a batch right now that will be done mid month.
Thanks Jay
[Re: moparmanjames]
#1745025
02/03/15 01:37 AM
02/03/15 01:37 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Thanks Jay
If you go that route, make sure your shifter is capable of the change. I know PPP shifter and Turbo Action Cheetah can both be used with a gate change.
[Re: J_BODY]
#1745028
02/03/15 11:36 AM
02/03/15 11:36 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I wish I would have done this because I never use my reverse position on the shifter.
Jay he should know with Dave's clean neutral v.b. neutral/reverse is the same shifter position, apply t-brake for reverse P-N/R-1-2-3-N. It helps to have a trans brake switch where it is comfortable for backing up.
"Just a Bracket car dressed up like a streetcar"
[Re: Mr.Yuck]
#1745031
02/03/15 01:35 PM
02/03/15 01:35 PM
moparmanjames
Las Vegas NV
? You should be coming out of the burn out box in 3rd. roll out bang it back up to N clean as needed drop to 1 and roll into staging. Or are you talking about the stripe at the big end?
The big end.
