Mopar Crankshaft Who makes the best??? #1744364
02/01/15 07:14 PM
02/01/15 07:14 PM
Connecticut, USA
sixty7gtx Offline OP
Connecticut, USA
I am looking for peoples option. Who makes the best MOPAR CRANKSHIFT?
Cali
Eagle
Mopar performance??
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Mopar Crankshaft Who makes the best??? [Re: sixty7gtx] #1744365
02/01/15 07:38 PM
02/01/15 07:38 PM
I've heard good regarding Ohio Crankshaft Company.
Re: Mopar Crankshaft Who makes the best??? [Re: sixty7gtx] #1744366
02/01/15 07:58 PM
02/01/15 07:58 PM
AndyF Offline
AndyF  Offline
The very best?? Or just something that works at 600 hp? Those are two different choices.
Re: Mopar Crankshaft Who makes the best??? [Re: AndyF] #1744367
02/01/15 08:12 PM
02/01/15 08:12 PM
Connecticut, USA
Connecticut, USA
600 HP... sound good. Thanks
1967 Plymouth GTX,
Re: Mopar Crankshaft Who makes the best??? [Re: sixty7gtx] #1744368
02/01/15 09:10 PM
02/01/15 09:10 PM
dogdays Offline
dogdays  Offline
For a 600hp engine there is no "best". All the $750 or so 4340 cranks come from the same forging dies, just different machining and not so sure about that!
The real answer to your question before you limited power output would be someone like Sonny Leonard or Winberg.
R.
Re: Mopar Crankshaft Who makes the best??? [Re: sixty7gtx] #1744369
02/01/15 09:11 PM
02/01/15 09:11 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Although I have not used his stuff yet but plan on it soon, Rod Bloomer of BPE seems to have some pretty good stuff. I learned about him from an engine builder friend of mine.
Joey
Re: Mopar Crankshaft Who makes the best??? [Re: dogdays] #1744370
02/01/15 09:21 PM
02/01/15 09:21 PM
R.
Sonny Leonrard or Sonny Bryant? OP, 600 HP on a Mopar wedge storker motor is not hard to do Plus you don't need a really good expensive all out forge steel racing crank to make that or live a long time as long as you build it right Get the oil clearances right and so on and you don't detonate the motor from tuning or bad fuel OP, how big of a motor are you wanting to build? Which heads, fuel and compression ratio? Lots of choices out there, a few gremlins also
Re: Mopar Crankshaft Who makes the best??? [Re: Cab_Burge] #1744371
02/01/15 09:23 PM
02/01/15 09:23 PM
dogdays Offline
dogdays  Offline
Yup, wrong Sonny...But any of the 4340 cranks will make enough power to kill a stock block.
R.
Re: Mopar Crankshaft Who makes the best??? [Re: dogdays] #1744372
02/01/15 09:24 PM
02/01/15 09:24 PM
R.
Dat be way TRUE , been there done that
Re: Mopar Crankshaft Who makes the best??? [Re: Cab_Burge] #1744373
02/01/15 09:25 PM
02/01/15 09:25 PM
Connecticut, USA
Connecticut, USA
R.
426 HEMI stroked to 500 HP. 4.375 stroke h beam rods. runs great. just getting some feedback.
1967 Plymouth GTX,
Re: Mopar Crankshaft Who makes the best??? [Re: sixty7gtx] #1744374
02/01/15 09:36 PM
02/01/15 09:36 PM
I've built and dyno tested a bunch of different Mopar motors of all types.The last pump gas 426 Street Hemi motor that I built and dnyo tested, 4.270 bore with 3.91 stroke, stock Mopar NOS late model iron replacement heads and stock street Hemi intake with 1967 carbs. made well over 500 HP(actaually nearer to 607 HP ) on CA pump gas at 10.5 to1 comp. ratio. My thinking is your motor will to Have you had it dyno tested or ran it at the track? If not maybe you got more HP and torque than you think I normally get more HP per C.I. from a N/A/ Mopar wedge than I do on them dang 426 Hemiroid motors I guess I'm not Hemi whisperer
Re: Mopar Crankshaft Who makes the best??? [Re: Cab_Burge] #1744375
02/01/15 10:38 PM
02/01/15 10:38 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I've read a lot of good things about Tom Molnar & Molnar cranks. Founder of K1 Technologies, sold it to Weisco, then started Molnar Technologies.
