Remove E-Body Steering Column #1743488
01/31/15 09:32 PM
01/31/15 09:32 PM
Georgia
Steve Bryant Offline OP
Georgia
How do I disconnect it from the steering box?
In stripping down the interior I have the column unbolted from the firewall and could easily pull it out but I am not sure how to disconnect it from the steering box.
To be honest, my box has a leak anyway so I may just go ahead and replace it too when I get the column out.
I did a few google searches and I see that there is a rod with splines that comes out of the gear box but I assume there is a button or retainer that I need to remove first before I start banging on it with a deadblow hammer!
Re: Remove E-Body Steering Column [Re: Steve Bryant] #1743489
01/31/15 09:51 PM
01/31/15 09:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Have you removed the roll pin yet?
Re: Remove E-Body Steering Column [Re: Steve Bryant] #1743490
01/31/15 11:28 PM
01/31/15 11:28 PM
NC
1970A66 Offline
1970A66  Offline
NC
You need to remove the roll pin that goes thru this coupler: http://www.ebay.com/itm/Mopar-B-E-Body-P...e1d&vxp=mtr
In the pic you can see the 2 holes in the right side of the coupler. That is where the roll pin is. Once the pin is removed, the coupler may have to be pried off the gear box splined shaft.
Re: Remove E-Body Steering Column [Re: 1970A66] #1743491
02/01/15 03:23 AM
02/01/15 03:23 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Here is another picture. The pin in the left center is what has to be removed. This pic is from GTX so the components may differ slightly but it is the same idea
Craig
Re: Remove E-Body Steering Column [Re: Steve Bryant] #1743492
02/01/15 03:39 AM
02/01/15 03:39 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Take a good look at what you're taking apart...There's a master spline on the steering box and the box/coupler need to go back together using it as the reference...
Disconnect the wiring connectors, unbolt the firewall plate and the upper column support bolts,drive the coupler rollpin out, then drop the column down off the two dash frame studs making sure the ground wire is disconnected and have someone help the coupler apart while you pull the column out and you're there...
Re: Remove E-Body Steering Column [Re: screamindriver] #1743493
02/01/15 10:23 AM
02/01/15 10:23 AM
Georgia
Georgia
Excellent! I will tackle that today. I already have new switches so I need to get the column out and take it apart for cleaning and painting and new electrical. While I have it out, I think I will go ahead and get a Firm Feel stage 2 since my current steering box has some wobble and its leaking a little bit.
Thanks again guys!
Re: Remove E-Body Steering Column [Re: Steve Bryant] #1743494
02/01/15 12:55 PM
02/01/15 12:55 PM
NC
1970A66 Offline
1970A66  Offline
NC
I put a Stage II box in my Challenger and love it.
If you have Saginaw power steering I strongly recommend this free and easy mod to reduce power steering pump pressure. This mod along with the Stage II box will give you close to a modern car feel of the road, providing everything underneath is tight with the steering and suspension.
http://www.moparaction.com/Tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
As I recall I installed 1/8 thick stack of washers, I'm thinking about adding more.
