'99 Voyager: dead instrument cluster, etc.
#1743479
01/31/15 08:50 PM
01/31/15 08:50 PM
Posts: 905 SD
zrxkawboy
SD
I am trying to help a friend with their '99 Voyager. The IC is completely dead and the CEL is on. He told me the problem started out being intermittent, but now is constant. He initially took it to the dealer, and here is what the repair ticket says: "Found codes P1698, P1695, P0125, P0743. Checked powers and grounds at TCM, all good. TCM BCM nonresponsive. Further diagnosis required."
I started with the battery. The dealer had cleaned the terminals well, and the battery tested good for me. The only code present was the P0743 (TCC circuit). I cleared the code, and when I started the van, the CEL was on immediately, and the P0743 was back. That's all the further we went, as it's about 20*F here, and my garage is unheated.
The van starts and runs well. Has anyone seen these particular symptoms? Would they point to cracked solder joints on the IC? Any advice appreciated!
It's Swifty! Swifty, you toad sucker!
Re: '99 Voyager: dead instrument cluster, etc.
[Re: rallye73]
#1743482
02/01/15 10:26 AM
02/01/15 10:26 AM
Posts: 19,396 north of coder
moparx
Pull the board off the back of the cluster. Flip it over and inspect the solder joints for the main connector on the board. As stated they are probably cracked. The first gen Neons did the same thing. Just resolder the joints and you should be good to go. I've done this twice on my Neon.
cold/cracked solder joints. they are sometimes very hard to see [if your eyes are like mine]. my 2000 caravan did that after the dash was put back together from an ac evaporator repair. resoldered the ic pins and all is good now for over 3/4 years.
