Re: hughes engines sb stud girdle [Re: humpty] #1743357
02/01/15 10:27 PM
02/01/15 10:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would not run the 4 bolt mains unless it was a magnum block and the bolts were wider so they could get into the extra meat in the pan rails.
I think the girdle could help keep the mains from deflecting to the front and back of the block, it is not going to do much up/down motion.
Re: hughes engines sb stud girdle [Re: Porter67] #1743358
02/01/15 10:47 PM
02/01/15 10:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You mention "harmonics", first time I've that issue addressed with a girdle. I don't know that it could not address that issue, but suspect it's more by accident then design. All my reasoning would have me agreeing Ryan. If I was asked to design a way to connect all the cap studs together with as much flexibility as possible, with 1/4" plate, this is the design I would use. If however connecting just the two studs together on each cap with 1/4" was the goal, it probably does a decent job, if that is the crux of the problem. However back to the first point here, harmonics can be solved many ways, but only best thru a lot of controlled expensive testing when using a design as complex as a SB running across a broad rpm range. And if that is the case, the OEM's likely just fix the original problem rather then band aid it.
I say we have a classic case of:
"In psychology and cognitive science, confirmation bias (or confirmatory bias) is a tendency to search for or interpret information in a way that confirms one's preconceptions, leading to statistical errors."
Re: hughes engines sb stud girdle [Re: HotRodDave] #1743359
02/01/15 11:18 PM
02/01/15 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 1 block(stock) with 4 bolt mains.. been a very
strong block for years.. it started out in the roundy
round stuff then I bought it
Re: hughes engines sb stud girdle [Re: humpty] #1743360
02/02/15 01:32 AM
02/02/15 01:32 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
if that fits a 360 block i'm very interested.
Re: hughes engines sb stud girdle [Re: mopar dave] #1743361
02/02/15 03:33 AM
02/02/15 03:33 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I have had one since they first came out whne I first built my 408 stroker from my factory magnum block. Stock main caps and 8rpm with ZERO signs of cap walk and my main bearings are always perfect looking on disassemble. I don't suggest doing 4-bolt splayed caps in a magnum block because if you look at the main webbing it doesn't have alot of meat there as it is. You got doing 4-bolt caps and you are just removing more meat from the webbings. Then you are adding the stress into the webbing area that is alredy the weak point of the block. I machined my main caps to sit the girdle down on them tight and the girdle also acts as a crank scraper. I have been spraying the piss out my 408 for shoot 8 years now, same crank,rods,pistons just new top end and rings/bearings. Never had to turn the crank once and I first built this motor back in 2004.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: hughes engines sb stud girdle [Re: slammedR/T] #1743362
02/02/15 02:11 PM
02/02/15 02:11 PM
Mt Morris Michigan
Mt Morris Michigan
a lot of good results with the hughes girdle. i'm convinced. i'll get one.
Re: hughes engines sb stud girdle [Re: mopar dave] #1743363
02/02/15 03:06 PM
02/02/15 03:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
put one in my 408 about 5 years ago to address a cap walk issue,,did it help? don't know haven't had it out of the car in 5 years.
Re: hughes engines sb stud girdle [Re: dartman366] #1743364
02/02/15 04:12 PM
02/02/15 04:12 PM
Mt Morris Michigan
Mt Morris Michigan
i'v been 8 yrs without one. time for a rebuild/reprogram with one. thanks for all your info guys. next combo should be a stout one.
Re: hughes engines sb stud girdle [Re: mopar dave] #1743365
02/02/15 05:20 PM
02/02/15 05:20 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I always felt that the design of a girdle on an SB wouldn't do much since it can't tie in the same way a BB one does...but after reading this thread and seeing how it has helped or prevented cap walk in a few applications, it has got me thinking.
I have stock 2 bolt caps, stock bolts and a half fill in my block. I shift my 408 at 6700 and cross the traps at 7k on spray..wonder if this would be a good idea for the motor when I eventually tear it down for a refresh (hopefully still in one piece when I do).
Re: hughes engines sb stud girdle [Re: mshred] #1743366
02/02/15 07:30 PM
02/02/15 07:30 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I think there is some misconception out there on how the girdle works, and what it's engineered purpose is.
The girdles intended purpose has NOTHING to do with resisting forces in the vertical direction. As correctly mentioned the 1/4" or 5/16" thickness will easily bend from the attachment points (same goes for a big block to a lesser degree).
What it is intended to do, is to prevent the caps from moving fore/aft in the block. As the crank is pushed down against the caps, they want to "splay" forward and rearward because of the bending forces from the crank. The girdle ties the caps together in a fore/aft manner preventing this from happening. This helps prevent that bending force from being transferred up the main webs and into the bulkheads also... meaning the benefits are not limited only to the cap/block interface joint.
The splayed caps only help the block/cap interface joint by increasing clamping, but do not prevent the bending forces from getting up/through the bulkhead in the block.
If you mill the tops of the cap down, and shim accordingly, it can also slightly increase the cap strength by "strapping" across the top of the cap.
Now there is a lot to debate here because all of these blocks were built long before FEA and computer modeling to review stresses, but in my opinion the proof is in the pudding with guys visually seeing differences in their teardown inspections after adding them.
Re: hughes engines sb stud girdle [Re: dizuster] #1743367
02/03/15 12:26 AM
02/03/15 12:26 AM
Az
Crizila Offline
Crizila  Offline
Az
Interesting - Concept. I've been through one teardown since going with my 4 bolt splayed caps and haven't visually seen any problems? Actually used the main bearings over again. Then again, I'm not running a rubber crankshaft.
Fastest 300
Re: hughes engines sb stud girdle [Re: Crizila] #1743368
02/03/15 06:25 AM
02/03/15 06:25 AM
slammedR/T Offline
slammedR/T  Offline
same for me, I have only put three sets of main bearings in this motor since I built in 2004. First set were clevites and i didn't care for them, second set were King's that i like and after using them twice I bought another set. I'm still running on them today(third re-use) I will prolly change these next time I crack the seal just cause I don't wanna re-use them more than three times.
racemagnum
Re: hughes engines sb stud girdle [Re: Crizila] #1743369
02/03/15 07:54 PM
02/03/15 07:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just to be clear, I'm not saying the 4-bolt caps don't work, or aren't an improvement. I'm just saying that they are doing a different thing then the girdle does.
The 4-bolt cap certainly does a good job keeping the cap clamped to the block which is a good thing. It also helps distribute the load across a wider section of the bulkhead which is also good. In a way it helps tie more of the main bulkhead back to the pan rail through mechanical fastening.
