Re: Two Piece Crank--440 go BOOM! [Re: 70Dustmite440] #1742815
02/04/15 10:12 AM
02/04/15 10:12 AM
Anonymous OP
Anonymous OP
727 burn outs-
Always start in 2nd--quick shiftto 3rd gets wheel speed up fast and the sprag is safe do one in first and when the wheels hit dry and chirp that sprag gets Whammed!!! Sooner or later it fails--it is press fit into case and has a small set screw to keep it from spinning--the bolt ins are a repair item not fool proof at all IMO.
Most Mopar guys have blown at least one before we discovered the weak link
NO first gear burn outs and you are safe as can be.
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742816
02/04/15 01:06 PM
02/04/15 01:06 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
I'll see what I can do
Heyy Big Todd and David, this is Eric from down in Jax FL.
Re: Two Piece Crank--440 go BOOM! [Re: 70Dustmite440] #1742817
02/04/15 01:08 PM
02/04/15 01:08 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I still start my burnout in first, either i'm too old to change my ritual or my engines are too weak starting in second... or both
I do too but always shift up when the tires are going without exception.
"I think its got a hemi"
Re: Two Piece Crank--440 go BOOM! [Re: gdonovan] #1742818
02/04/15 07:49 PM
02/04/15 07:49 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I don't ever let the tires chirp. I'm out of the throttle as soon as it's rolling out of the water (3rd gear).
Doug
Re: Two Piece Crank--440 go BOOM! [Re: dvw] #1742819
02/04/15 07:52 PM
02/04/15 07:52 PM
California
mickm Offline
mickm  Offline
California
so i know very little about automatics, what is the problem with doing a burnout in first gear?
Re: Two Piece Crank--440 go BOOM! [Re: mickm] #1742820
02/04/15 07:54 PM
02/04/15 07:54 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The problem is the tires getting traction and the sudden stop in first will damage the overrunning clutch, explosion can follow.
In simple terms.
Re: Two Piece Crank--440 go BOOM! [Re: gdonovan] #1742821
02/04/15 07:59 PM
02/04/15 07:59 PM
California
mickm Offline
mickm  Offline
California
In simple terms.
ok, makes perfect sense, with what little i know!
so i guess that would be true for any automatic, modified or not?
Re: Two Piece Crank--440 go BOOM! [Re: mickm] #1742822
02/04/15 08:04 PM
02/04/15 08:04 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I just know Chrysler, can't speak for GM or Ford.
Even the race units with bolt in sprags or the later RWD OD units (which also have a bolt in sprag) it would be a bad idea to shock the drivetrain in first gear. Just a roller and spring arrangement that does not take kindly to the abuse.
Re: Two Piece Crank--440 go BOOM! [Re: mickm] #1742823
02/04/15 08:12 PM
02/04/15 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In simple terms.
Not really... a STOCK VB has the LBA(low band apply)
a RMVB with out LBA the low band isnt applied if
just in drive... if you pull it down into low(1st)
then it applies the band... the thing with the over
running clutch is.. if the tires are spinning and
the ORC(over running clutch.. or known as the sprag)
it can load and unload... that forward SLAM on it
can break it... usually the next hard load on it just
blows the ORC then.. (this is the important part)
the forward drum will turn 2.2 times faster than the
engine rpm... pretty much anything over 6200 engine
rpm and the drum will centrifugally explode... hope
that gives you a idea of what happens
EDIT
If you start in 2nd with a MRVB(or just a manual VB)
you are not using the ORC so you dont have the issue
low gear is a issue on the 727.. thats why its advised
to get out of it ASAP.... never pedal a 727 in low..
shift first
Re: Two Piece Crank--440 go BOOM! [Re: MR_P_BODY] #1742824
02/04/15 08:20 PM
02/04/15 08:20 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Thanks Mr.P, been awhile since I heard the explanation, seen plenty of pics of the results though!
Re: Two Piece Crank--440 go BOOM! [Re: gdonovan] #1742825
02/04/15 08:31 PM
02/04/15 08:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a lot of typing for me so I think I got it all
right.. the big thing is get out of low ASAP... second
and high arent a issue... and NEVER pedal in low..
that is when you slam the ORC... shift first
Re: Two Piece Crank--440 go BOOM! [Re: MR_P_BODY] #1742826
02/04/15 09:03 PM
02/04/15 09:03 PM
California
mickm Offline
mickm  Offline
California
ok, did get most of that, but what do you mean "pedal in low"?
Re: Two Piece Crank--440 go BOOM! [Re: mickm] #1742827
02/04/15 09:08 PM
02/04/15 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On and off the gas.. that is when the ORC will load
and unload.. the loading can break it... if it unloads
in low.. shift before you get back on it
Re: Two Piece Crank--440 go BOOM! [Re: MR_P_BODY] #1742828
02/04/15 09:56 PM
02/04/15 09:56 PM
California
mickm Offline
mickm  Offline
California
Re: Two Piece Crank--440 go BOOM! [Re: mickm] #1742829
02/04/15 10:52 PM
02/04/15 10:52 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I am running a Turbo Action "auto" valve body, extra line pressure etc. In drive, do I have to worry about the tires spinning and then hooking while the shifter is in Drive and the trans is still in low?
Side note, I am also using an A&A sprag etc.
