Page 3 of 4 1 2 3 4
Re: Measuring pinion angle for Dana 60 [Re: B G Racing] #174212
12/25/08 07:18 PM
12/25/08 07:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Quicktree at PRI show
Re: Measuring pinion angle for Dana 60 [Re: sixpackgut] #174213
12/25/08 07:23 PM
12/25/08 07:23 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That certainly explains everything,
Re: Measuring pinion angle for Dana 60 [Re: sixpackgut] #174214
12/25/08 07:29 PM
12/25/08 07:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
gee thanks RAY payback is hell
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174215
12/25/08 07:31 PM
12/25/08 07:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think I fell asleep when Eddie was telling us how great he is
Re: Measuring pinion angle for Dana 60 [Re: sixpackgut] #174216
12/25/08 07:34 PM
12/25/08 07:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hey why doidn't you show the pic of me kicking your butt on the practice tree?
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174217
12/25/08 07:39 PM
12/25/08 07:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Tony,looks like you were dreaming about rearends and angles.Merry Christmas
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174218
12/25/08 07:42 PM
12/25/08 07:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a picture is worth a thousand words
i beat your but on the practice tree. .480 to .530 every time!!!!!!!!!!!!!
Re: Measuring pinion angle for Dana 60 [Re: B G Racing] #174219
12/25/08 07:42 PM
12/25/08 07:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no i was just trying to keep him from blinding me with his stupid camera.
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174220
12/25/08 07:46 PM
12/25/08 07:46 PM
U.S.
moparniac Offline OP
U.S.
so what would the concensus say the correct pinion angle for a caltrac setup should be... i think it was 5* nose down with ss springs.....
gut where have you lost all that weight at....
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174221
12/25/08 07:47 PM
12/25/08 07:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what ever caltrac tells you, did you read the instructions
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174222
12/25/08 07:49 PM
12/25/08 07:49 PM
U.S.
U.S.
didnt say. but i emailed him......
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: Quicktree] #174223
12/25/08 07:51 PM
12/25/08 07:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We set Caltracs/split mono leaf springs at 2 degrees negative of the driveshaft.
Re: Measuring pinion angle for Dana 60 [Re: B G Racing] #174224
12/25/08 07:53 PM
12/25/08 07:53 PM
U.S.
U.S.
i dont know how my crap is 9* down on the dana .......
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174225
12/25/08 07:55 PM
12/25/08 07:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Calvert recomends not using caltracs with SS springs. here is the deal. you dont want your angles going positive. if your using just spings, 5-7* down is perfect. caltracs and ladders 2* down. i tried shims and i dont like them and wont use them. i would try it as is.
lost weight on front seats, rear window regulaters, and willwood brakes on the front and removal of emergency brake.
on the wish list is
aluminum driveshaft with 1350 joints and centerlines on the back. that could get me to 3600 maybe
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174226
12/25/08 08:11 PM
12/25/08 08:11 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
at one time that was a good thing.
is that 9* minus driveshaft angle?
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174227
12/25/08 08:52 PM
12/25/08 08:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With Caltracs and springs I think its 2* to 4* down. Thats from the tranny parallel angle and not the shaft. When John returns your Email he will confirm that. mike
Re: Measuring pinion angle for Dana 60 [Re: Sport440] #174228
12/25/08 09:20 PM
12/25/08 09:20 PM
U.S.
U.S.
I run caltracs and the split mono's.... on my old 8 3/4 setup measuring off the shaft was 0* and i believe 2* up on the snubber pad.... I used a cut lowering block to fix that...
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: sixpackgut] #174229
12/25/08 09:21 PM
12/25/08 09:21 PM
U.S.
U.S.
- 9(down) on the dana and -3(down) on the back of the tranny.. not -2 as previously posted... so im taking its -12* down
dont have a driveshaft yet.....
im mounted on the upper hole of the front spring hanger also I feel if I went to the lower hol the dana pinion angle would be worse... maybe im wrong...
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174230
12/25/08 09:47 PM
12/25/08 09:47 PM
U.S.
U.S.
so would I need to get to +1 up on the dana to have -2 nose down total....
Mopar Performance
Re: Measuring pinion angle for Dana 60 [Re: moparniac] #174231
12/25/08 10:41 PM
12/25/08 10:41 PM
When your posting your numbers where are you measuring with a angle finder? Off of both the tranny and rear end in relationship to the 90 mark or what? If in relationship to 90 degrees are both measurements on the same side or opposite sides of the 90 mark? If both are on the same side then you need to subtract them from each other which would equal six degrees difference between the two angles, if there on opposite sides of the 90 degree mark you add them together which ends up equaling 12 degrees like you posted, which is way to much
Page 3 of 4 1 2 3 4
