Vibration at 45 mph after replacing torsion bars #1742011
01/30/15 12:41 AM
01/30/15 12:41 AM
atlanta, ga
taboo Offline OP
taboo  Offline OP
atlanta, ga
My wife and I purchased a 71 challenger 440 six pack 4 speed car, that was originally a 318 automatic car. We both enjoy working on the car but we are stumped on this one.
The car drove well when we originally purchased it but had a noticeable vibration at 75mph for the first year. We later noticed the car was bottomed out on the lower control arm bumpers. We ended up replacing the torsion bars with 0.96" bars and we were able to get the car ride height corrected (the old torsion bars were actually swapped right and left and were clearly worn out). We took the car to a chain store to get the alignment done afterwards and ever since then we have had a violent vibration that starts at 45mph that seems to settle out at 55 mph and have nearly no vibration at 60+. The vibration occurs at these speeds even if I take it out of gear. Also, I believe it is in the rear as I do not feel it in the steering wheel.
I thought the problem was the tires as they were 10+ years old, so we ended up changing both the wheels and tires, but still have the same issue. I was wondering what the next troubleshooting step would be. Any help would be greatly appreciated!
Re: Vibration at 45 mph after replacing torsion bars [Re: taboo] #1742012
01/30/15 01:12 AM
01/30/15 01:12 AM
IN
ahy Offline
ahy  Offline
IN
As a start in troubleshooting, changing the T bars should not affect the rear. Sounds like the shakes came before wheel/tire replacement. For trouble shooting, as it may be in the rear suggest 1) check rear U joints for slop 2) put the front on ramps and with a helper to turn the wheel, check for slop in front end joints 3) Get it aligned and re-balanced at a good shop. There are not a lot of shops that are good with T bar suspension. A good tech will check tires for out of round at least visually while balancing. 4) Report back.
Re: Vibration at 45 mph after replacing torsion bars [Re: ahy] #1742013
01/30/15 01:23 AM
01/30/15 01:23 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
And there lies the problem . A tire can be perfectly balanced but still be out of round. have tires checked for out of roundness and balance again . check drive shaft and u joints , sometime a bad shock with a little out of balance can seem like a real bad balance issue .
Re: Vibration at 45 mph after replacing torsion bars [Re: mopar_man] #1742014
01/30/15 01:30 AM
01/30/15 01:30 AM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
I had a similar issues at around 60MPH. The rear tire tread on my BFGs was separating.
2 new tires in the back and it all went away.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Vibration at 45 mph after replacing torsion bars [Re: RobG] #1742015
01/30/15 01:46 AM
01/30/15 01:46 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I had a vibration in a Dart years ago. A buddy of mine had me unhook the drive shaft and rotate it 180* and hook it back up. It didn't fix it but it reduced it.
...FAFO...
Re: Vibration at 45 mph after replacing torsion bars [Re: RobG] #1742016
01/30/15 01:46 AM
01/30/15 01:46 AM
atlanta, ga
taboo Offline OP
taboo  Offline OP
atlanta, ga
Thank you for the quick replies. I should mention that I actually replaced (not changed) all 4 wheels and tires with new and had them balanced. There was no change in the vibration after doing this. I will look in to the other suggestions. Thank you!
Re: Vibration at 45 mph after replacing torsion bars [Re: skicker] #1742017
01/30/15 01:53 AM
01/30/15 01:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is interesting!
Re: Vibration at 45 mph after replacing torsion bars [Re: Kern Dog] #1742018
01/30/15 02:08 AM
01/30/15 02:08 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Jack the car up, put jack stands under the rear end. Start the car, put it in gear and give it some gas. You should be able to see if it is a bent rim, bad tire, or drive shaft problem.
Re: Vibration at 45 mph after replacing torsion bars [Re: taboo] #1742019
01/30/15 02:52 AM
01/30/15 02:52 AM
shaft/ujoints/extension housing bushing
Re: Vibration at 45 mph after replacing torsion bars [Re: taboo] #1742020
01/30/15 08:27 AM
01/30/15 08:27 AM
NE
moparpoolman Offline
NE
You're probably noticing the vibration more after torsion bars installed because the car is stiffer/more rigid. What kind of tires did you put on the car? I've seen many of the repro tires "out of round" and balancing can not fix that. I'd also check the transmission mount.
Re: Vibration at 45 mph after replacing torsion bars [Re: moparpoolman] #1742021
01/30/15 06:03 PM
01/30/15 06:03 PM
P
Paul_Fancsali Offline
P
Did anyone dent the driveshaft ?They did that at the one shop I had my car I had to replace the shaft
Re: Vibration at 45 mph after replacing torsion bars [Re: Kern Dog] #1742022
01/30/15 06:06 PM
01/30/15 06:06 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
I did the same thing on my challenger it reduced it to almost nothing
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Vibration at 45 mph after replacing torsion bars [Re: azmopar] #1742023
01/30/15 06:24 PM
01/30/15 06:24 PM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
a little too much axle runout can cause a vibration that comes and goes.
Re: Vibration at 45 mph after replacing torsion bars [Re: RapidRobert] #1742024
01/30/15 09:11 PM
01/30/15 09:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Transmission mount can do this too.
- Stu Harmon
Re: Vibration at 45 mph after replacing torsion bars [Re: Paul_Fancsali] #1742025
01/31/15 01:51 AM
01/31/15 01:51 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
As can a driveshaft that is too short.
Re: Vibration at 45 mph after replacing torsion bars [Re: rowin4] #1742026
01/31/15 05:26 AM
01/31/15 05:26 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I did this once when I had a bad vibration in a ONE ton Dodge truck. You'd think the mass of a truck that heavy wouldn't vibrate much. It turns out that one of the FREE tires a buddy gave me was on a seriously bent wheel. I'm talking a wheel that was bent at least 1 1/2 inches! After pulling the wheel, I could clearly see the bend in the center section. I looked at the other three wheels and two others were AFU as well.
SOME buddy, huh???
Re: Vibration at 45 mph after replacing torsion bars [Re: Kern Dog] #1742027
01/31/15 11:38 AM
01/31/15 11:38 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
What condition are the lower control arm bushings in.
Re: Vibration at 45 mph after replacing torsion bars [Re: TC@HP2] #1742028
01/31/15 02:07 PM
01/31/15 02:07 PM
that was the prob with my 65 dart 318/904/7&1/4, not enough front yoke engagement into the trans. It would vibrate part time. rounded up a slightly longer shaft/swapped the front yoke/ujoints & all good. The tip off was that I could see on the front yoke where it was worn smooth on a prior vehicle but now alot of that length was surface rusted as it was not engaging into the trans (wrong shaft or wrong yoke)
