Re: Measuring pinion angle for Dana 60
[Re: sixpackgut]
#174214
12/25/08 07:29 PM
12/25/08 07:29 PM
Quicktree
Quicktree at PRI show
gee thanks RAY payback is hell
[Re: sixpackgut]
#174216
12/25/08 07:34 PM
12/25/08 07:34 PM
Quicktree
hey why doidn't you show the pic of me kicking your butt on the practice tree? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Quicktree]
#174218
12/25/08 07:42 PM
12/25/08 07:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
a picture is worth a thousand words ![](/ubbthreads/images/graemlins/biggrin.gif) i beat your but on the practice tree. .480 to .530 every time!!!!!!!!!!!!!
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: B G Racing]
#174219
12/25/08 07:42 PM
12/25/08 07:42 PM
Quicktree
Tony,looks like you were dreaming about rearends and angles.Merry Christmas
no i was just trying to keep him from blinding me with his stupid camera.
[Re: Quicktree]
#174220
12/25/08 07:46 PM
12/25/08 07:46 PM
Posts: 6,295 U.S.
moparniac
U.S.
so what would the concensus say the correct pinion angle for a caltrac setup should be... i think it was 5* nose down with ss springs.....
gut where have you lost all that weight at....
Mopar Performance
[Re: moparniac]
#174221
12/25/08 07:47 PM
12/25/08 07:47 PM
Quicktree
what ever caltrac tells you, did you read the instructions ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: moparniac]
#174225
12/25/08 07:55 PM
12/25/08 07:55 PM
sixpackgut
Charleston
Calvert recomends not using caltracs with SS springs. here is the deal. you dont want your angles going positive. if your using just spings, 5-7* down is perfect. caltracs and ladders 2* down. i tried shims and i dont like them and wont use them. i would try it as is.
lost weight on front seats, rear window regulaters, and willwood brakes on the front and removal of emergency brake.
on the wish list is aluminum driveshaft with 1350 joints and centerlines on the back. that could get me to 3600 maybe
[Re: Sport440]
#174228
12/25/08 09:20 PM
12/25/08 09:20 PM
Posts: 6,295 U.S.
moparniac
U.S.
I run caltracs and the split mono's.... on my old 8 3/4 setup measuring off the shaft was 0* and i believe 2* up on the snubber pad.... I used a cut lowering block to fix that...
Mopar Performance
