Re: What size headers tubes on your B1 combo's [Re: steve660] #1741836
01/31/15 02:57 AM
01/31/15 02:57 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Interesting post. Im having 622 with PSO heads built and will need headers. It is a pump gas engine with shift points around 7000ish in a 72 Barracuda. Have been told TTI 2"-2 1/8" step with 3 1/2 collector will e enough. Im kinda skeptical about them. If need be ill have custom ones made.
Exactly what my sb w9 headers are.
Re: What size headers tubes on your B1 combo's [Re: go green] #1741837
01/31/15 11:53 AM
01/31/15 11:53 AM
The Great White North
RAMM Offline
RAMM  Offline
I did 2.375" on my Coronet years ago and would never do it again . I don't care what some calculator says , it has to fit in car.A 2.25" would work just as good and it is way easier to buy and find in stainless or carbon . The B1 is only a 1.78" valve so its not fooling anybody by putting a macho pipe in it.
This is good advice ^^^^^. I would also advise against anything bigger than a 4" collector. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: What size headers tubes on your B1 combo's [Re: RAMM] #1741838
01/31/15 02:13 PM
01/31/15 02:13 PM
Mo.
racerx Offline
racerx  Offline
Mo.
It does make a lot of sense
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741839
01/31/15 02:13 PM
01/31/15 02:13 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
B1 heads only please but I am soon going to be having a set of headers made for my B1 headed 572. Probably going to be a stepped header type design but what are you guys running. This will be for a nitrous combo. Thanks
John,
Mines 2 1/2" with 5" collectors...Not saying you need this size,but know one has been faster with B1 originals than us with our/your type car...Your gonna have more torque than you can use at the start and can use all the HP it can make out the back door !!
Just sayin !!
Re: What size headers tubes on your B1 combo's [Re: Gary Robbins] #1741840
01/31/15 02:26 PM
01/31/15 02:26 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
John,
Just sayin !!
Thanks again guys. I have more room than I thought I would but shes not bolted in yet.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What size headers tubes on your B1 combo's [Re: Gary Robbins] #1741841
01/31/15 05:51 PM
01/31/15 05:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
John,
Just sayin !!
For your type of car Gary makes a very good argument. If you have to pull power anyway you might as well gain it on the top. I was thinking slow tanks like mine that need the torque.
Doug
