Re: What size headers tubes on your B1 combo's
[Re: steve660]
#1741836
01/31/15 02:57 AM
01/31/15 02:57 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Interesting post. Im having 622 with PSO heads built and will need headers. It is a pump gas engine with shift points around 7000ish in a 72 Barracuda. Have been told TTI 2"-2 1/8" step with 3 1/2 collector will e enough. Im kinda skeptical about them. If need be ill have custom ones made.
Exactly what my sb w9 headers are.
[Re: RAMM]
#1741838
01/31/15 02:13 PM
01/31/15 02:13 PM
Posts: 4,085 Mo.
racerx
Mo.
I did 2.375" on my Coronet years ago and would never do it again . I don't care what some calculator says , it has to fit in car.A 2.25" would work just as good and it is way easier to buy and find in stainless or carbon . The B1 is only a 1.78" valve so its not fooling anybody by putting a macho pipe in it.
This is good advice ^^^^^. I would also advise against anything bigger than a 4" collector. J.Rob
It does make a lot of sense ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: pittsburghracer]
#1741839
01/31/15 02:13 PM
01/31/15 02:13 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
B1 heads only please but I am soon going to be having a set of headers made for my B1 headed 572. Probably going to be a stepped header type design but what are you guys running. This will be for a nitrous combo. Thanks
John, Mines 2 1/2" with 5" collectors...Not saying you need this size,but know one has been faster with B1 originals than us with our/your type car...Your gonna have more torque than you can use at the start and can use all the HP it can make out the back door !!
Just sayin !!
[Re: Gary Robbins]
#1741841
01/31/15 05:51 PM
01/31/15 05:51 PM
Posts: 9,895 MI, usa
dvw
MI, usa
Just sayin !!
For your type of car Gary makes a very good argument. If you have to pull power anyway you might as well gain it on the top. I was thinking slow tanks like mine that need the torque. Doug
